How to get Value of select menu ?
Thread begun 4/28/2010 10:01 am by Fritz Stickers | Last modified 5/02/2010 3:56 am by Fritz Stickers | 5758 views | 13 replies |
Fritz Stickers
How can I get the value of a select menu (form name = FrogStyling_1_Size_Add) ?
The select menu has the choice of a few sizes :
size 10 = € -1,00
size 15 = € = 4,00 <!--(rsDetail.Fields.Item("ProductPrice").Value) : initially selected-->
size 20 = € +2,00
size 25 = € +4,00
size 30 = € +6,00
size 35 = € +8,00
The standard price is shown. I want the price show to what the customer selected.
I had this to begin, but get this : error 'ASP 0102 : 80004005' :
<% If Request.Form(FrogStyling_1_Size_Add)=10 Then
Response.Write(FormatNumber(((rsDetail.Fields.Item("ProductPrice").Value)-1), 2, -2, -2, -2))
Else
Response.Write(FormatNumber(((rsDetail.Fields.Item("ProductPrice").Value)+5), 2, -2, -2, -2))
End If %>
My site is in ASP VBscript.
you could do this using javascript on the onchange event of the select list, here is a small example:
price: $<span id="price">13</span>
<br />
<form id="form1" name="form1" method="post" action="">
Price List'
<select name="priceList" id="priceList" onChange="document.getElementById('price').innerHTML = document.form1.priceList[document.form1.priceList.selectedIndex].value">
<option value="12">Item 1 - $12</option>
<option value="13" selected="selected">Item 2 - $13</option>
<option value="14">item 3 - $14</option>
</select>
</form>
Fritz Stickers
Thanks !
It works but the option values are needed in the eCart to calculate the price, which depends on the choosen size. So I can't change them like in your model.
<select name="FrogStyling_1_Size_Add" id="FrogStyling_1_Size_Add"  class="textfieldReg" onchange="document.getElementById('cmPrice').innerHTML = document.FrogStyling_1_ATC_<%=rsDetail.Fields("ProductID").value%>.FrogStyling_1_Size_Add[document.FrogStyling_1_ATC_<%=rsDetail.Fields("ProductID").value%>.FrogStyling_1_Size_Add.selectedIndex].value" >
<option value="10">10 cm - &euro; 1,00</option>
<option value="15" selected="selected">15 cm</option>
<option value="20">20 cm + &euro; 2,00</option>
<option value="25">25 cm + &euro; 4,00</option>
<option value="30">30 cm + &euro; 5,00</option>
<option value="35">35 cm + &euro; 6,00</option>
<option value="40">40 cm + &euro; 7,00</option>
<option value="45">45 cm + &euro; 8,00</option>
<option value="50">50 cm + &euro; 9,00</option>
<option value="55">55 cm + &euro; 10,00</option>
</select>
Isn't it possible to change the .value of the onchange event with a conditional statement ?
sure, you could create a function to look up the price
function getPrice(option) {
var thePrice;
switch (option) {
case '10':
thePrice = '1,00';
break;
case '15':
thePrice = '2,00';
break;
case '20':
thePrice = '3,00';
break;
case '25':
thePrice = '4,00';
break;
case '30':
thePrice = '5,00';
break;
case '35':
thePrice = '6,00';
break;
case '40':
thePrice = '7,00';
break;
case '45':
thePrice = '8,00';
break;
case '50':
thePrice = '9,00';
break;
case '55':
thePrice = '10,00';
break;
default:
thePrice = '2,00';
return thePrice;
</script>
the change the onchange script to:
onchange="document.getElementById('cmPrice').innerHTML = getPrice(document.FrogStyling_1_ATC_<%=rsDetail.Fields("ProductID").value%>.FrogStyling_1_Size_Add[document.FrogStyling_1_ATC_<%=rsDetail.Fields("ProductID").value%>.FrogStyling_1_Size_Add.selectedIndex].value)"
Fritz Stickers
This also works. :) But thePrice is supposed to add 2, 4, 5, 6, ... to (rsDetail.Fields.Item("ProductPrice").Value).
I tried to change it, but it gives "NaN" back.
I hope you understand what I mean with the "var prodPrice" ?
var prodPrice = document.getElementById("cmPrice").innerHTML
var thePrice;
switch (option) {
case '10':
thePrice = (prodPrice)-1;
break;
case '15':
thePrice = (rsDetail.Fields.Item("ProductPrice").Value);
break;
case '20':
thePrice = (prodPrice)+2;
break;
case '25':
thePrice = (prodPrice)+4;
break;
case '30':
thePrice = (prodPrice)+5;
break;
case '35':
thePrice =(prodPrice)+6;
break;
case '40':
thePrice = (prodPrice)+7;
break;
case '45':
thePrice = (prodPrice)+8;
break;
case '50':
thePrice = (prodPrice)+9;
break;
case '55':
thePrice = (prodPrice)+10;
break;
default:
return thePrice;
</script>
please send your page in a zip archive so i can see the code in context.
Fritz Stickers
See attach "Geert".
ok, do it this way instead. pass the price as another var in the onchange event:
onchange="document.getElementById('cmPrice').innerHTML = getPrice(document.FrogStyling_1_ATC_<%=rsDetail.Fields("ProductID").value%>.FrogStyling_1_Size_Add[document.FrogStyling_1_ATC_<%=rsDetail.Fields("ProductID").value%>.FrogStyling_1_Size_Add.selectedIndex].value, <%= FormatNumber((rsDetail.Fields.Item("ProductPrice").Value), 2, -2, -2, -2) %>)"
and change the function to take the extra param:
function getPrice(option, prodPrice) {
var thePrice;
switch (option) {
case '10':
thePrice = prodPrice-1;
break;
case '15':
thePrice = prodPrice;
break;
case '20':
thePrice = prodPrice+2;
break;
case '25':
thePrice = prodPrice+3;
break;
case '30':
thePrice = prodPrice+4;
break;
case '35':
thePrice = prodPrice+5;
break;
case '40':
thePrice = prodPrice+6;
break;
case '45':
thePrice = prodPrice+7;
break;
case '50':
thePrice = prodPrice+8;
break;
case '55':
thePrice = prodPrice+9;
break;
default:
thePrice = prodPrice+10;
return thePrice;
</script>
Fritz Stickers
That's working fine, but prices with 2 decimals are not showing right.
e.g.: 4,25 + 2 = 6 ... must be 6,25
I tried a lot of stuff, like Math.Round, toFixed(), ... in vain.
Is this one necessary :
default:
How works "prodPrice", is it a variable ?
it's because the number is being passed using the comma as a decimal separator, javascript does not recognize the comma as a decimal separator
try this function instead, it will convert the comma to a period:
var prodPrice = prodPrice.replace(",",".");
var thePrice;
switch (option) {
case '10':
thePrice = parseFloat(prodPrice)-1;
break;
case '15':
thePrice = parseFloat(prodPrice);
break;
case '20':
thePrice = parseFloat(prodPrice)+2;
break;
case '25':
thePrice = parseFloat(prodPrice)+3;
break;
case '30':
thePrice = parseFloat(prodPrice)+4;
break;
case '35':
thePrice = parseFloat(prodPrice)+5;
break;
case '40':
thePrice = parseFloat(prodPrice)+6;
break;
case '45':
thePrice = parseFloat(prodPrice)+7;
break;
case '50':
thePrice = parseFloat(prodPrice)+8;
break;
case '55':
thePrice = parseFloat(prodPrice)+9;
break;
default:
thePrice = parseFloat(prodPrice)+10;
return thePrice;
</script>
also in the onchange event, there needs to be single quotes around the price that is being passed:
onchange="document.getElementById('cmPrice').innerHTML = getPrice(document.FrogStyling_1_ATC_<%=rsDetail.Fields("ProductID").value%>.FrogStyling_1_Size_Add[document.FrogStyling_1_ATC_<%=rsDetail.Fields("ProductID").value%>.FrogStyling_1_Size_Add.selectedIndex].value, '<%= FormatNumber((rsDetail.Fields.Item("ProductPrice").Value), 2, -2, -2, -2) %>')"
