image editing error
Thread begun 4/27/2010 3:43 pm by Stan.Shaw269802 | Last modified 5/11/2010 10:46 am by Jason Byrnes | 2955 views | 7 replies |
Stan.Shaw269802
image editing error
When a user attempts to edit an image at the URL "HTMLEditor/editor/plugins/kfm/index.php?lang=default&kfm_caller_type=fck&type=Image" an error message is displayed "PHP Notice: Undefined index: REQUEST_URI in HTMLEditor\editor\plugins\kfm\plugins\cropper\croparea.php on line 34"
What needs to be done to correct this?
*note - I have removed the beginning of each URL above to what the generic URL would be.
what version of PHP are you running?
Are you hosting on IIS or apache?
Try adding the following at line 1 of the page you have applied HTML editor to:
<?php $_SERVER['REQUEST_URI'] = substr($_SERVER['PHP_SELF'],0); ?>
Stan.Shaw269802
PHP Version 5.2.12
IIS 6
Sorry, don't understand "page you have applied HTML editor to"
The intent here is to edit an image, do you mean the page the image is in?
I mean the page you go to that has the html editor instance on it.
The page with the html editor text area that has the image icon in the tool bar used to launch the HTML Editor image editing window.
Stan.Shaw269802
I added the line to the page: contents_update.php is that what you are asking be done?
The result was the same when I clicked on an image and select "crop image"
PHP Notice: Undefined index: REQUEST_URI in ...\HTMLEditor\editor\plugins\kfm\plugins\cropper\croparea.php on line 34
ok, try adding that line to the HTMLEditor\editor\plugins\kfm\plugins\cropper\ croparea.php page instead.
Stan.Shaw269802
Ok, that seems to have eliminated the error message but necessarily resolved the issue.
When I attempt to crop a photo, the page to do so opens with the image X (the standard way of showing an image can not be displayed).
An attempt to view an image results in the same red x box as above.
Resizing an image appears to do so correctly, as I did so and viewed it outside of Power CMS.
Is it possible there is a simple solution to all of these issues?
Are these commonly used functions?
I think the issue is that you are using windows hosting that is not defining the REQUEST_URI server variable.
maybe try using this code instead:
if (!isset($_SERVER['REQUEST_URI']))
$_SERVER['REQUEST_URI'] = substr($_SERVER['PHP_SELF'],);
       if (isset(
$_SERVER['QUERY_STRING'])) { $_SERVER['REQUEST_URI'].='?'.$_SERVER['QUERY_STRING']; }
