Upload page not working
Thread begun 4/27/2010 3:29 pm by mrobben375515 | Last modified 4/30/2010 1:03 pm by Eric Mittman | 5271 views | 12 replies |
mrobben375515
I tried to create an upload page and I keep getting the .php?invalid=true extension after I hit insert. The data doesn't go into the database and the code doesn't make it to the email redirect so I'm sure something is wrong with the insert record. the url is upload_file.php and I've attached the file. Thanks in advance
The validations are failing, this is why you get the valid = false in the URL. To determine what validation is failing you should add a new line just after line 29 and put this code in the new line:
die("the WAFV_Errors are: " . $WAFV_Errors);
This will let you know what validations are failing by the number, you can then look at the validation number on your page to see what one is failing. It looks like you have validations ranging from 1 to 6 currently on the page. Please post back and let us know what the result is.
mrobben375515
the WAFV_Errors are: ,3
so it has to do with the insert record behavior "File" field. right now I have the value set to
<?php echo ((isset($_FILES["Log_in_group_File"]))?$_FILES["Log_in_group_File"]["name"]:""); ?>
I'm not sure what to set it to. I tried setting it to the simple file name, but that didn't work either.
The value that you are specifying for the insert is fine, it is the form element that you are validating that is the problem. Instead of referring to it as $_POST["Log_in_group_File"] you should refer to it as $_FILES["Log_in_group_File"]. Try updating line 24 to be like this:
$WAFV_Errors .= WAValidateRQ((isset($_FILES["Log_in_group_File"])?$_FILES["Log_in_group_File"]:"") . "",true,3);
I think this will get it working correctly for you.
mrobben375515
works like a charm...thanks
mrobben375515
so I tried to make another upload page on a different site, after I finished the page I went and changed the POST to FILES and it worked. Then I added a universal email behavior and now I get these lines of errors...I've attached the php doc...the url is upload_files.php
Warning: Unexpected character in input: '\' (ASCII=92) state=1 in /home/content/61/5153161/html/webassist/email/waue_upload_files_1.php on line 47
Warning: session_start() [function.session-start]: Cannot send session cookie - headers already sent by (output started at /home/content/61/5153161/html/webassist/email/waue_upload_files_1.php:47) in /home/content/61/5153161/html/webassist/email/mail_php.php on line 285
Warning: session_start() [function.session-start]: Cannot send session cache limiter - headers already sent (output started at /home/content/61/5153161/html/webassist/email/waue_upload_files_1.php:47) in /home/content/61/5153161/html/webassist/email/mail_php.php on line 285
Warning: session_start() [function.session-start]: Cannot send session cookie - headers already sent by (output started at /home/content/61/5153161/html/webassist/email/waue_upload_files_1.php:47) in /home/content/61/5153161/html/upload_files.php on line 170
Warning: session_start() [function.session-start]: Cannot send session cache limiter - headers already sent (output started at /home/content/61/5153161/html/webassist/email/waue_upload_files_1.php:47) in /home/content/61/5153161/html/upload_files.php on line 170
Warning: Cannot modify header information - headers already sent by (output started at /home/content/61/5153161/html/webassist/email/waue_upload_files_1.php:47) in /home/content/61/5153161/html/upload_files.php on line 172
The error is coming from webassist/email/waue_upload_files_1.php, please post back with that file so we can take a look at it.
mrobben375515
here it is....
Thanks for the file, I think that I can see the problem, it looks like the page that was used for the message was originally a template. It seems that the template declarations are coded with js script possibly. If you can post back with the page the email body was derived from I might be able to see why it was set like this.
To fix it try updating line 47 in waue_upload_files_1.php to be like this instead:
$MailBody = $MailBody . "<!-- In\"+\"stanceEndEditable --><!-- In\"+\"stanceEndEditable --></body> <!-- In\"+\"stanceEnd --><!-- In\"+\"stanceEnd --></html>";
Let us know how this works for you.
mrobben375515
Now it works, thanks for the help. Do you mean the derived page as in the upload_files.php that I created it from? I can upload whatever file if it'll help you guys...
