Driving Directions does not display
I can not get the driving directions to display.
Officelocation.php
Bob
Officelocation.php
Bob
try changing the destination address to:
2305 South Easton Ave, Bethlehem, PA, 18017
Google cannot calculate the directions, because the destination is not specific enough.
I tried to change the address; the driving directions still do not display.
When I go to Google and use the address it works fine.
when I view your page it is still using the "2305 Easton Ave, Bethlehem, PA, 18017, USA".
Maps.google.com uses a different geocoding service than the Google Map API does. The one used by the Google Map API Is not as forgiving as the one used by maps.google.com.
I created six maps and two of them had the same problem. I corrected the problem by going to Google Maps and typing in the address and Google suggested a different address for the same location, by using this one the maps worked fine.
Bob Hahn
ok, glad you got it sorted.
