Undefined variable: totalRows_ error
Thread begun 4/26/2010 10:43 am by Joe Lowery | Last modified 4/26/2010 2:15 pm by Jason Byrnes | 2181 views | 3 replies |
Joe Lowery
I used DataAssist to add a new set of management pages to my PowerStore site. When I run the results page, I get the following error:
Notice: Undefined variable: totalRows_WADAevents in C:\inetpub\wwwroot\Ellen Celli Jewelry\Admin\events.php on line 63
No records are displayed, even though there is definitely one in the database.
Here's the code for the first part of my page (line 63 is the last line of code before the closing php tag):
<?php require_once( "../WA_Globals/WA_Globals.php" ); ?>
<?php require_once('../Connections/localhost.php'); ?>
<?php require_once("../WA_DataAssist/WA_AppBuilder_PHP.php"); ?>
<?php require_once("../WA_ValidationToolkit/WAVT_Scripts_PHP.php"); ?>
<?php require_once("../WA_ValidationToolkit/WAVT_ValidatedForm_PHP.php"); ?>
<?php require_once( "../WA_SecurityAssist/Helper_PHP.php" ); ?>
<?php require_once( "../WADbSearch/HelperPHP.php" ); ?>
if (!WA_Auth_RulePasses("Administrator")){
WA_Auth_RestrictAccess("index.php");
if (PHP_VERSION < 6) {
switch ($theType) {
case "text":
break;
case "long":
case "int":
break;
case "double":
break;
case "date":
break;
case "defined":
break;
return $theValue;
$currentPage = $_SERVER["PHP_SELF"];
$queryString_WADAevents = "";
if (!empty($_SERVER['QUERY_STRING'])) {
$params = explode("&", $_SERVER['QUERY_STRING']);
$newParams = array();
foreach ($params as $param) {
if (stristr($param, "pageNum_WADAevents") == false &&
stristr($param, "totalRows_WADAevents") == false) {
array_push($newParams, $param);
if (count($newParams) != 0) {
$queryString_WADAevents = "&" . htmlentities(implode("&", $newParams));
$queryString_WADAevents = sprintf("&totalRows_WADAevents=%d%s", $totalRows_WADAevents, $queryString_WADAevents);
Any ideas what could be wrong?
Best - Joe
Hi Joe, the probelm is code order.
The Recordset code that defines $totalRows_WADAevents is after this block of code that is using it:
move the WADAevents code before this code so the $totalRows_WADAevents variable will created before it is being used.
Joe Lowery
Thanks, Jason - that did it!
No worries Joe, glad to hear it worked.
