Payments Pro and Sandbox testing
Thread began 4/26/2010 10:43 am by ben_bradley348417 | Last modified 8/27/2014 10:24 am by Jason Byrnes | 6075 views | 22 replies |
ben_bradley348417
PS2
After waiting 2 months to finally work out how to get a paypal account approved for my client, I am now back trying to finally finish this store. Just one of the things that wasn't mentioned in the purchase, lol!
Anyhow, im now testing the site - index.php
My problem is when a purchase has been made, in the '/Admin/orders_Update.php?OrderID=1' page, it is asking me to send confirmation and the tracking number, but it wont let me as it keeps on asking me an error on the phone number "Please enter a phone number to call with shipping quesions." I put 11 digits in, it goes green, blank fax, and update, and keeps coming up with the same error.
At this point, I still cant make a test transaction from paypal.
Also, any thoughts on how to change 'Zip' to 'Post Code', and also removing 'States' to make it for the UK. Also, how do you add Royal Mail as a shipping?
Any thoughts, will be greatly appreciated please. Thanks in advance!
ben_bradley348417
Any replies would be greatly recieved please!
I have looked into this a little and it seems that you are using PowerStore 2, the phone number validation is not a part of PowerStore 3, only the fax would be validated.
You can remove the validation or alter it so that the number is not required, removing it might be the easiest way to get past this issue. At the top of your orders update page look for this line of code:
$WAFV_Errors .= WAValidatePN(((isset($_POST["OrderPhone"]))?$_POST["OrderPhone"]:"") . "",true,false,true,8);
You can safely remove it to stop the validation from occurring on the number. This should allow you to send the order confirmation. This should not have any effect on a test transaction though, the order must be placed and recorded before you will be able to send any confirmation.
As for changing zip to postal code you can change any of the labels that you see on the pages to say postal code instead, this will not have an effect on anything. The same goes for the states, it is just a static list that you can update to include areas or whatever else would make sense to put in there.
ben_bradley348417
Thanks for your reply Eric, I've managed to send a shipped confirmation now. However, Im still seeing no transfer exchange of money in Paypal sandbox testing? Also, how do I make the site SSL secure, when entering card details? It is supposed to be Web Payments Pro.
i.edwards384429
update
Hi
If you are useing PS3 I have modified it to reflect UK counties and post codes.
Providing support Ok it ,I'll let you have the code to change it
cheers
Ian
I think this one is using PS2, but if you two would like to exchange code updates that is ok, but the complete files should not be posted here in the forum.
As for your transactions not occurring for the PayPal do you have test mode set to true in your globals file? If so you will need to set it to false. Also, check that you have the use sandbox set to true for sandbox testing.
When you are checking on transaction that occurred in the sandbox you will need to sign into the sandbox area to with your testing account to see the details. If you see no details here then it means that no transaction occurred, this is usually only the case when the test mode is enabled.
ben_bradley348417
Eric, I currently have had the test mode=true, and the sandbox=true. I can get a order go through the process. But, I cant get the transaction of money in sandbox. When test mode=false, I get through sandbox paypal to put the details in for the transaction and the order confirmation, then when I submit to confirm order (pp_confirm), it goes to checkout failure (pp_checkout_failure).
What is wrong please?
Is the checkout.php page ssl encrypted when I get it to go live?
Also, how do I join UPS and get the shipping gateway working? I've opened an account and looked at the shipping api, but dont understand how to link the two, and theres nothing from both parties to explain.
If you are test mode turned off and are getting to the failure page with the sandbox or live mode then you will need to add in the debug info to your failure pages to see what the problem might be.
On you pp_checkout_failure and the checkout_failure pages add this into the source on the pages, it will print out all of the api interactions that are occurring. This should let you know what the error is, please post back with what you discover.
if(!session_id()) session_start();
if(
$WAGLOBAL_Gateway == ) {
echo
"<p>Direct Pay: <br />"
echo
"Full Request: ".(isset($_SESSION["PP_DirectPayment_postedValues"])?htmlentities($_SESSION["PP_DirectPayment_postedValues"]):"n/a")."<br />"
echo
"Full Response: ".(isset($_SESSION["PP_DirectPayment"])?htmlentities($_SESSION["PP_DirectPayment"]):"n/a")."<br /></p>"
echo
"<p>Express Authorize <br />"
echo
"Full Request: ".(isset($_SESSION["ECO_Auth_Request"])?htmlentities($_SESSION["ECO_Auth_Request"]):"n/a")."<br />"
echo
"Full Response: ".(isset($_SESSION["ECO_Auth_Result"])?htmlentities($_SESSION["ECO_Auth_Result"]):"n/a")."<br />"
echo
"<p>Express Process: <br />"
echo
"Full Request: ".(isset($_SESSION["ECO_Process_Request"])?htmlentities($_SESSION["ECO_Process_Request"]):"n/a")."<br />"
echo
"Full Response: ".(isset($_SESSION["ECO_Process_Result"])?htmlentities($_SESSION["ECO_Process_Result"]):"n/a")."<br /></p>"
if(
$WAGLOBAL_Gateway == 2) {
echo
"<p>Auth Net: <br />"
echo
"Full Request: ".(isset($_SESSION['WAAuthNet_postedValues'])?htmlentities($_SESSION['WAAuthNet_postedValues']):"n/a")."<br />"
echo
"Full Response: ".(isset($_SESSION['WAAuthNet'])?htmlentities($_SESSION['WAAuthNet']):"n/a")."<br /></p>"
if(
echo
"<p>Express Authorize: <br />"
echo
echo
"Full Response: ".(isset($_SESSION["ECO_Auth_Result"])?htmlentities($_SESSION["ECO_Auth_Result"]):"n/a")."<br /></p>"
echo
echo
echo
if(
$WAGLOBAL_Shipping == 1) {
echo
"<p>UPS: <br />"
echo
"Full Request: ".(isset($_SESSION["WA_Store_Cart_UPS_FullRequest"])?htmlentities($_SESSION["WA_Store_Cart_UPS_FullRequest"]):"n/a")."<br />"
echo
"Full Response: ".(isset($_SESSION["WA_Store_Cart_UPS_FullResponse"])?htmlentities($_SESSION["WA_Store_Cart_UPS_FullResponse"]):"n/a")."<br /></p>"
if(
$WAGLOBAL_Shipping == 2) {
echo
"<p>FedEX: <br />"
echo
"Full Request: ".(isset($_SESSION["WA_Store_Cart_FedEx_FullRequest"])?htmlentities($_SESSION["WA_Store_Cart_FedEx_FullRequest"]):"n/a")."<br />"
echo
"Full Response: ".(isset($_SESSION["WA_Store_Cart_FedEx_FullResponse"])?htmlentities($_SESSION["WA_Store_Cart_FedEx_FullResponse"]):"n/a")."<br /></p>"
if(
$WAGLOBAL_Shipping == 3) {
echo
"<p>USPS: <br />"
echo
"Full Request: ".(isset($_SESSION["WA_Store_Cart_USPS_FullRequest"])?htmlentities($_SESSION["WA_Store_Cart_USPS_FullRequest"]):"n/a")."<br />"
echo
"Full Response: ".(isset($_SESSION["WA_Store_Cart_USPS_FullResponse"])?htmlentities($_SESSION["WA_Store_Cart_USPS_FullResponse"]):"n/a")."<br /></p>"
For signing up to UPS I found this info from Joe Lowery on the Adobe Developer Connection:
  GETTING UPS ACCESS
To start, visit the My UPS sign up page at registration. Review the service agreement terms and conditions; if you wish to proceed, click Accept at the bottom of the page. On the next page, fill in basic contact information such as name, street address, telephone number, and e-mail address; developers should enter their own information rather than that of a client. The final step is to establish a username and password.
Once you have a My UPS account, register with them as an end-user of their online tools. Log onto your My UPS account and then visit toolintro?loc=en_US&WT.svl=SubNav; and select the Get Tools link (located on both the left and right side of the page). When the Get Tools page opens, choose the link to the UPS Rates & Service Selection in the Standard Tools section. You may need to provide the additional information requested before you can proceed. After you've registered with their online tools division, you'll receive an e-mail with a developer's key. The developer's key has two purposes: It gives you access to all the UPS documentation for implementing their online tools, and it is needed to retrieve a UPS Access Key, which, in turn, is required to actually communicate with the UPS web services.
UPS offers two varieties of services, one HTML-based and the other rooted in XML. The XML version is far more robust and allows connection to all of UPS' services worldwide whereas the HTML version is limited to two services (UPS Tracking and UPS Rates & Service Selection) and only between the United States and Puerto Rico
ben_bradley348417
ben_bradley348417
moved to private
