Using PowerCMS Installation Wizard
Thread begun 4/25/2010 10:40 am by bmccondichieq261536 | Last modified 4/27/2010 6:54 am by Jason Byrnes | 2491 views | 4 replies |
bmccondichieq261536
I am attempting to use PowerCMS Installation Wizard, but do not know where to start, can you help me with this?
ron.haysbert231945
Have you up loaded the site
Once you upload the site map you path to the CMS2/admin/index.php the wizard should start for you.
i.edwards384429
install
Hi
Unzip the files onto your desktop.
rename the root directory to something like powercms.
Upload that whole directory to your web server ie the directory powercms
In your browser type
powercms/
The install sequence will start automatically.
HTH
Ian
bmccondichieq261536
no luck
I am using PowerCMS102, I renamed my local rood folder to powercms, uploaded the CMS files and tried to find and run the wizard with no luck. I have no experience with php, so I do not know what to look for if its right or wrong.
Please help
PowerCMS 1 does not include an installation wizard, you will need to manually edit the WA_Globals.php file to configure PowerCMS for your site.
see the following tutorials for assistance installing PowerCMS 1:
powercms_globals.pdf
powercms_creating_content.pdf
sp_db_connection.pdf
importing_sql.pdf
