error
Thread begun 4/23/2010 8:18 am by i.edwards384429 | Last modified 5/06/2010 10:17 am by Jason Byrnes | 5798 views | 14 replies |
i.edwards384429
error
Hi
I went to upgrade a csm1 installation on a page using the user registration module.
The set up goes through and asks me if I want to convert/import data into the new format.
When I test the page I getr the following error
Fatal error: Cannot redeclare WA_AuthenticateUser() (previously declared in C:\wamp\www\1stmodelagency\WA_SecurityAssist\Helper_PHP.php:10) in C:\wamp\www\1stmodelagency\PowerCMS\WA_SecurityAssist\Helper_PHP.php on line 48
I have compared the two files and they are different.
I gather I'm re decaleing something. what do I comment out and in what file?
thanks
Ian
i.edwards384429
update
Been checking my site and I use two logon sequences, one using the user registration solution and the other using the the security assist extension.
On both of these pages which contain a cms section I get the error
thanks
Ian
there are two require once lines on the page to add the security assist helper file, remove one of them.
i.edwards384429
update
Hi Jason
sorry to be a pain I've attached the logon file and I can only see one call for helper_php.php
Is it called via the cms2 code? In any case as the files appear to be different which one should be deleted
cheers
Ian
yes, it is atached in the PowerCMS/WA_CMS/WA_CMS.php
delete the security assist one:
<?php require_once( "WA_SecurityAssist/Helper_PHP.php" ); ?>
i.edwards384429
more problems
Hi
I deleted the line in users_login.php andthat page now loads.
When a user logs in the error is now displayed and the address moves to
users_profile.php
I went into that file and deleted the same line but that has the effect of preventing the page from redirecting to users_profile.php ie it stays on login.php
any ideas?
thanks
Ian
add this into the page:
<?php require_once( "WA_SscurityAssist/HelperGroupsRulesPHP.php" ); ?>
i.edwards384429
update
Hi Jason
I assume the fingers went a bit wrong ;-) so I deleted the line
<?php // require_once( "WA_SecurityAssist/Helper_PHP.php" ); //?>
and added
<?php require_once( "WA_SecurityAssist/HelperGroupsRulesPHP.php" ); ?>
into the head of users_profile.php
If I now preview the page on my local test server I get the error
Fatal error: Cannot redeclare WA_Auth_GetComparisonsForRule() (previously declared in C:\wamp\www\1stmodelagency\PowerCMS\WA_SecurityAssist\HelperGroupsRulesPHP.php:2) in C:\wamp\www\1stmodelagency\WA_SecurityAssist\HelperGroupsRulesPHP.php on line 46
I say, isn't life fun?
cheers
Ian
i.edwards384429
update
Hi Jason
Any luck on a solution to my problem or have I got the techies really puzzled?
cheers
Ian
I was stumped on this one for a bit, but I think I have a work around.
get your pages back to where the where before, then make a backup copy of the PowerCMS/WA_CMS/WA_CMS.php file, save it as WA_CMS2.php
In the backup version, comment out line 5:
//require_once( "../WA_SecurityAssist/Helper_PHP.php" );
on your pages, cahnge the following:
<?php include("PowerCMS/WA_CMS/WA_CMS.php"); ?>
<?php include("PowerCMS/WA_CMS/WA_CMS2.php"); ?>
