PHP page blank
Thread begun 4/23/2010 6:02 am by tom.kurshinsky298027 | Last modified 4/23/2010 10:17 am by Jimmy Wu | 2897 views | 4 replies |
PHP page blank
DataAssist 2.0.6
I created a basic PHP/MySQL page and when I go to the page it loads with no errors, but the page is blank, no text, nothing. If I just do a simple data display page with Dreamweaver the data shows fine.
CraigRBeta Tester
is sounds like you have a syntax error in your php.
can you upload the page ?
Here it is.
CraigRBeta Tester
try adding the following code to the top of your php page..
error_reporting(E_ALL);
Jimmy Wu
If a PHP page loads as blank, it means that an error has occurred, but error reporting is turned off. As Craig posted, if you put that code at the top of the page and go through the page again, then the errors will be displayed instead of a blank page. Please copy and paste the error that is returned in your next response.
