Discounts in eCart
Thread begun 5/24/2009 6:18 pm by duncanc213061 | Last modified 6/08/2009 10:02 am by duncanc213061 | 9595 views | 19 replies |
duncanc213061
Discounts in eCart
I have a customer who is selling products, and he wants to sell six of a specific item, and only that item, for $15.00, and any additional (>6) he wants to sell for 10.00.
Can't for the life of me figure out the discount merchandising rule.
Thank you in advance.
Add Columns to the cart: DiscountMin and DiscountAmount
In this case set them to 6 and 5 respectively.
Then update the calculation:
TotalPrice = [Price] * [Quantity] - (([Quantity]>[DiscountMin])?([Quantity]-[DiscountMin])*[DiscountAmount]:0)
duncanc213061
Discounts in eCart
Would I not be able to apply the discounts in the discounts rules in the cart, because there are other items with varying multiples.
Thanks, Duncan
The example I gave would allow you to have different multiples for each item.
If you want to use a discount rule instead then add the columns just as I have asked, but don't update the TotalPrice, instead add a new calculation:
TotalDiscount = (([Quantity]>[DiscountMin])?([Quantity]-[DiscountMin])*[DiscountAmount]:0)
Then you can add a discount rule to subtract the total of the TotalDiscount calculation from the cart total.
duncanc213061
Discounts in eCart
I have tried what you said by adding the two columns, and adding the calculations.
The calculations are: [Price] * [Quantity] -(([Quantity]>[DiscountMin])?([Quantity]-[DiscountMin])*[DiscountAmount], and now I am getting this error:
Error Type:
Microsoft VBScript compilation (0x800A0408)
Invalid character
/drbirdie/WA_eCart/birdie_VB.asp, line 180, column 89
itmObj.TotalPrice = itmObj.Price * itmObj.Quantity -((itmObj.Quantity>itmObj.DiscountMin)?(itmObj.Quantity-itmObj.DiscountMin)*itmObj.DiscountAmount'c
Additionally, do I need to set anything else in the rules to make this work properly?
Duncan
I gave you the php answer... in vbscript it would be:
[Price] * [Quantity] -(abs([Quantity]>[DiscountMin])*([Quantity]-[DiscountMin])*[DiscountAmount])
duncanc213061
Discounts in eCart
Ray:
Thanks, that did the trick!!
Now one final how to:
I have two items, Golf Club A, and Golf Club B, both are 119.00, but I want a discount of 10.00 if a person wants to buy one of A and one of B.
Thanks,
Duncan
Add a discount rule if both Item A and item B are in the cart give them $10 discount.
duncanc213061
Discounts in cart
I have tried to work through the discounts, but am unsuccessful on a major one:
VBScript
I added the two columns as you said, and I now want to show the discount on the summary cart.
When I do the discounts, it takes a discount for ALL of the golf clubs, and not just for any quantity over 6 clubs.
The trigger is:
Number of items with price of 46.17 > 6
Calculation is:
Subtotal of DiscountAmount times 1 minus 0
Si is stands to reason that if a customer orders 8 clubs, the discount shoud be 36.34, but the discount is that shows is 145.36
It looks like DiscountAmount must be calculated improperly. What did you use in the calculation for DiscountAmount?
