Your security code entry did not match the image
Thread begun 4/22/2010 1:57 pm by tolushayoo193471 | Last modified 4/23/2010 2:33 pm by Jason Byrnes | 9177 views | 7 replies |
tolushayoo193471
Hi, just uploaded the contact form solution pack, i only change the dommie email to my email address in WA_Global.php then reuploaded all i tried test it, but when i submit the form the captcha image kepts on displaying "Your security code entry did not match the image." and it's actually matches it and i dont know why it kept on showing these, since the security code i entered it the wright one.
thank you
the first place to start is to test your servers session management.
See the following post for a script you can use for testing session management on the server:
showpost.php?p=23826&postcount=2
Please post back a link to your contact page and the sessionTest.php file.
tolushayoo193471
thank you, here is link to the pages:
session test: sessionTest.php
contact page: contact_styled.php
hmmm, session management is working on the server.
lets try this to help troubleshoot, find the following code:
if ($WAFV_Errors != "")  {
    PostResult($WAFV_Redirect,$WAFV_Errors,"contact");
and change it to:
    die("<pre>Sessions: ".var_dump($_SESSION)."</pre><br /><pre>POST: ".var_dump($_POST)."</pre><br />Errors: ".$WAFV_Errors);
this will help me see what's going wrong.
tolushayoo193471
thank you i've done that and here is the errror
array(2) { ["random_answer"]=> string(6) "monday" ["WAVT_contact_Errors"]=> string(0) "" } array(7) { ["Contact_Name"]=> string(0) "" ["addblock"]=> string(0) "" ["Email_address"]=> string(0) "" ["seconddblock"]=> string(0) "" ["Comments"]=> string(0) "" ["Security_code"]=> string(0) "" ["Security_question"]=> string(0) "" }
Sessions:
POST:
Errors: ,1,2,3,4,5
hmmm, doesn't look like the captcha session is gettting set.
try changing:
<img  src="WA_ValidationToolkit/WAVT_CaptchaSecurityImages.php?noisecolor=<?php echo $WAGLOBAL_Captcha_Noise; ?>&bgcolor=<?php echo $WAGLOBAL_Captcha_BG; ?>&textcolor=<?php echo $WAGLOBAL_Captcha_Text; ?>&transparent=<?php echo $WAGLOBAL_Captcha_BG_transparent; ?>&characters=<?php echo $WAGLOBAL_Captcha_Characters; ?>&width=<?php echo $WAGLOBAL_Captcha_Width; ?>&height=<?php echo $WAGLOBAL_Captcha_Height; ?>&font=<?php echo $WAGLOBAL_Captcha_Font; ?>" alt="security code" /><br  />
<img  src="WA_ValidationToolkit/WAVT_CaptchaSecurityImages.php?field=1&noisecolor=<?php echo $WAGLOBAL_Captcha_Noise; ?>&bgcolor=<?php echo $WAGLOBAL_Captcha_BG; ?>&textcolor=<?php echo $WAGLOBAL_Captcha_Text; ?>&transparent=<?php echo $WAGLOBAL_Captcha_BG_transparent; ?>&characters=<?php echo $WAGLOBAL_Captcha_Characters; ?>&width=<?php echo $WAGLOBAL_Captcha_Width; ?>&height=<?php echo $WAGLOBAL_Captcha_Height; ?>&font=<?php echo $WAGLOBAL_Captcha_Font; ?>" alt="security code" /><br  />
tolushayoo193471
thank you, i think the error is still the same
array(2) { ["random_answer"]=> string(3) "wet" ["WAVT_contact_Errors"]=> string(0) "" } array(7) { ["Contact_Name"]=> string(4) "GHHH" ["addblock"]=> string(0) "" ["Email_address"]=> string(18) "tolushayoo@aol.com" ["seconddblock"]=> string(0) "" ["Comments"]=> string(7) "cvbcbvc" ["Security_code"]=> string(0) "" ["Security_question"]=> string(0) "" }
Sessions:
POST:
Errors: ,4,5
login.php
