Contact me BUTTON doesn't work..
Thread begun 4/22/2010 12:05 pm by james276087 | Last modified 4/23/2010 3:36 pm by james276087 | 3660 views | 6 replies |
james276087
Hello there,
we're having funny weather in Los Angeles, Ca.this week, beautiful snow on the mountains and strong winds and rain.....hepe in Europe have better weather there.
Anyway from the form i made for Contact request, Button for Contact me doesn't work...
It did work ( i think) and now not working ....any advice
thanks for reading
ps.contactus.php?invalid=true
the ?invalid=true query string variable means that one of the validations is failing.
To pinpoint which one, locate the following code:
if ($WAFV_Errors != "")  {
    PostResult($WAFV_Redirect,$WAFV_Errors,"contact");
and change it to:
    die($WAFV_Errors);
this will write a coma separated list of numbers to the screen and help us determine which validation is failing.
Please post back a copy of your page so we can examine the code to determine the cause of the problem.
james276087
Still doesn't work, after click on Button direct to blank page n show " .6".
I attached the code
thank you
well, like I said, that code would help me troubleshoot the problem, not fix it.
So if it is writing 6 to the screen, that means captcha is not validating.
the first place to start is to test your servers session management.
See the following post for a script you can use for testing session management on the server:
showpost.php?p=23826&postcount=2
james276087
Jason,
When i click Second Link show " Session Test = NULL "..
Server has a problem with session management????
Then what can I do??
thanks
you will need to contact your hosting provider to have them fix the problem. Show them the session test script and they should be able to have the problem fixed fairly quickly.
james276087
As always give me the right answer..
thanks again Jason n have nice weekend
