error
Thread begun 4/22/2010 8:58 am by i.edwards384429 | Last modified 4/23/2010 12:08 pm by Eric Mittman | 2372 views | 3 replies |
i.edwards384429
error
Hi
I unstalled DFP because I now have UE4 now when ever I try to insert flash I get the error
JavaScript error while loading WA_DFP_Filedelete.htm
unable to open C:\.........wa_configuration.js
So clearly it's looking for DFP file thats not there do I re install or is there another solution?
thanks
Ian
Have you tried clearing out the cache file? If not here are instructions on how to do this:
If you have tried this and still get the error there might be a configuration corruption. Here are some steps you can take to get the configuration recreated:
showpost.php?p=12293&postcount=2
Post back and let us know if you still have the problem.
i.edwards384429
update
Hi Eric
had to delete the configuration file and re install the extensions ( as re enable failed)
problem fixed
cheers
Ian
Seems like there was definitely something left over from the previous install. It is good to hear that you have got it worked out.
