Surveyor Not Submitting
Thread begun 4/21/2010 4:15 pm by sales244435 | Last modified 7/19/2010 9:49 am by Jason Byrnes | 5766 views | 11 replies |
sales244435
Hello,
Surveyor is Not Submitting to the Search engines. Before we would get a few notices as usual via the web browser. Now we hit the submit button and the application UI disappears, then nothing happens.
We are using CS3 and never had this issue before. We even uninstalled the older version, then installed the newer version so we are up to date now, same results.
Please advise if anyone has a cure for this.
Jimmy Wu
Is this happening for all sites or just a specific site? Do you have the sitemap stored locally or on a live server?
sales297222
Yes, it is not submitting on any sites, I just tried it again.
Interesting.
Please advise when you can, Thank you!
Jimmy Wu
What is the behavior when you try to submit a sitemap? Do you get any error messages, any browser windows open up or anything like that?
sales297222
Re: Not Submitting
Hello,
When we hit the submit button, the Application diapers, no web browsers open (they used to...), no errors either. You just click the submit and nothing happens, weird.
I have tried many different options - un-ticking, ticking the application options, but the same end results.
I am on a Mac all is current, software is all current ++ but this never happened before.
Thank you again for yoru time.
Jimmy Wu
Did you install any extensions between when the extension was working and when it stopped working? Do all the other extensions you have installed work fine?
Have you tried uninstalling and re-installing the extension?
Did you completely remove the previous version before installing the latest?
sales244435
Hello,
Yes, we un-installed the extension, then installed the new one. We updated a few WebAssist extension, but nothing that come to mind that was installed before or after we noticed this interruption. Since we are on a Mac, maybe we will try to create a new user and see is the fresh preferences will cure this too?
Eventually we will find this issue I am sure...
Thank you again!
Jimmy Wu
Do you have any firewall, security or virus scan software running while running the extension?
Did you install using the same user that you are running it on? Are you installing on the Administrator user?
faith352588
Surveyor has stopped submitting
I'm having the same problem with Surveyor submitting fine and then has just recently stopped. Any help would be appreciated.
Jimmy Wu
Could you elaborate a little more on the behavior of surveyor when it doesn't submit? Does it pop up any error messages or browser windows, etc?
