Record View Counter, Update Record, Increment
Thread begun 4/21/2010 3:11 pm by dlovas275157 | Last modified 4/23/2010 1:25 pm by Jason Byrnes | 5668 views | 9 replies |
dlovas275157
When using ADDT, I created a record view counter. In my database, each record had a numeric column entitled viewCount. On page load (for a record's detail page), the page had a custom transaction as follows that would add 1 to the number in the viewCount column:
// Make a custom transaction instance
$countViews = new tNG_custom($conn_wmConn);
$tNGs->addTransaction($countViews);
// Register triggers
$countViews->registerTrigger("STARTER", "Trigger_Default_Starter", 1, "VALUE", "1");
// Set custom transaction SQL
$countViews->setSQL("UPDATE wm_inventory SET viewCount = viewCount + 1 WHERE id = {GET.id}");
// Add columns
// End of custom transaction instance
This would increment the viewCounter column in my database for that record by 1 when its detail page was loaded.
How can I go about setting up something similar with WebAssist's extensions? I have played around with adding an dataassist update record sb, but doesn't seem to work.
Thanks for any help.
D.
On the bindings panel, click the plus button, an select URL variable. Set the name to id.
Then add the Data Assist Update record server behavior.
Set the trigger to "Before Page Load"
For the Key column select the id column. next to Key Column value, click the lightning bolt and select the id URL variable from the bindings list.
On the second page, select the viewCount column, then click the lightning bolt next to value. From the detail page recordset, select the viewCount column. This will add code similar to:
<?php echo $row_RecordsetName['viewCount']; ?>
change that to:
<?php echo $row_RecordsetName['viewCount']++; ?>
finally, make sure that the forms action will pass the id querystring when it posts, change the forms action to:
<?php echo $_SERVER["PHP_SELF"]; ?><?php echo (isset($_SERVER["QUERY_STRING"]) && $_SERVER["QUERY_STRING"] != "")?"?".$_SERVER["QUERY_STRING"]:""; ?>
dlovas275157
Jason,
I followed up till the last step where it says "finally, make sure that the forms action will pass".
There is not a form on the page.
d'ho, right, it's a detail page, the update occurs on load.
never mind the form action part.
dlovas275157
It does not appear to be working. I have attached my page code.
The link to get my detail page is as follows (it passes 1 url parameter "gid") should i use it instead of "id" as in your example. I tried that as well but it did not work either.
detail.php?gid=978
Thanks again for your help.
well, yes, if the page is using the gid query string, that is the one you will need to use in the update record behavior.
your sample code at the begining used "id" that is why I used that in the instructions:
to trouble shoot the problem, find:
$MM_editCmd = mysql_query($WA_Sql, $WA_connection) or die(mysql_error());
and change it to:
die($WA_Sql);
this will write the update SQL to the screen.
try using this sql directly on the database in PHPMyAdmin or some other MySQL GUI tool.
dlovas275157
Jason,
Thanks for your patience. I have replace the code with the die code as your recommended. It outputs the following sql:
UPDATE `ws_inventory` SET `viewCount` = 1 WHERE `id_inventory`=980
viewCount is always output as equal to the current value in the database (not one over the current value)
If I run this on the database in PHPMYADMIN it sets the view count to 1 for that specific record (#980).
Attached are screenshots of update record wizard steps and code.
using:
<?php echo $row_rsGuns['viewCount']++; ?>
should increment it by 1.
Maybe try explacitly ading 1 instead:
<?php echo $row_rsGuns['viewCount']+1; ?>
dlovas275157
That worked!!
For some reason
would not work for me....
Changing it to:
worked!!
Thanks for your patience and prompt replys.
D.
excellent, glad to hear it is working.
