setting tabindex
Thread begun 4/21/2010 11:44 am by dinohorn397192 | Last modified 5/03/2010 10:07 am by dinohorn397192 | 2295 views | 4 replies |
dinohorn397192
setting tabindex
How would I tabindex from one form field to the HTML editor field ?
example...
<div class="fieldGroup"> <span id="Edit_group_Bio_Spry">
// WebAssist iRite: Rich Text Editor for Dreamweaver
$WARichTextEditor_1 = CreateRichTextEditor ("Edit_group_Bio", "../../HTMLEditor/", "600px", "300px", "Custom", "../custom/edit_Edit_group_Bio1.js", "".$row_pawRS['PawsBio'] ."");
<span class="textareaMinCharsMsg">Minimum number of characters not met.</span><span class="textareaRequiredMsg">Please add at least 10 characters about your beloved pet :)</span> </span>
if (ValidatedField('edit','edit')) {
if ((strpos((",".ValidatedField("edit","edit").","), "," . "3" . ",") !== false || "3" == "")) {
if (!(false)) {
<span class="serverInvalidState" id="Edit_group_Bio_ServerError">Please add at least 10 characters about your beloved pet :)</span>
<?php //WAFV_Conditional edit.php edit(3:)
</div>
I have looked into this a bit and it seems that I'm able to tab into the editor but I did not find a way to set the tab index. I looked around and saw a few things that mentioned this was not supported in the editor.
This is not a feature that we are currently supporting within the editor.
dinohorn397192
If your able to tab into the editor, do you have any tabindexes setup on the form? Do you have an index before and after?
In my test I did not have tab indexes. I tried it out by adding some to the elements before and after the text editor and I found that the editor will be the last one to get the tab. So it seems that any element that has a tab index will occur before this one.
dinohorn397192
Thanks, works great now.
