Securtiy Assist -set up
Thread begun 4/21/2010 9:59 am by sunshine64231 | Last modified 4/21/2010 11:14 am by Neil Beadle | 1421 views | 1 replies |
sunshine64231
I have downloaded and installed the product including the support files. The instructions that come with the product do not match the files in the support package so I am having difficulty even getting started. Can you provide a WORKING set of files (including an actual complete data base with sample entries) and instructions for THOSE files. I am using a UNIX server as both the live and testing server. I access the server and MYSQL through PLESK 8.06 but I need a complete working database to start with. (Your instructions refer to different databases and are different from those in the support package...and indicate a table has to be created)
I am on a Vista machine locally and upload files through ftp (not Dreamweaver).
thanks
Neil Beadle
We have a free MySQL database that contains all the tables you would need available from here:
ecommerce-database/
The users table in this database contains everything most websites will need and everything you should need to apply SecurityAssist.
With this database, the Getting Started Guide should be able to guide you through understanding how to implement SecurityAssist.
securityassist/
