Cart problem
Thread begun 5/24/2009 1:21 pm by dbotdesigns379943 | Last modified 5/26/2009 10:20 am by Ray Borduin | 3470 views | 2 replies |
dbotdesigns379943
Cart problem
I have ecart up and running.It was pretty straight forward but on one of the items (one with some custom javascript options) if you add another item with different options it replaces the options from the first with the options of the second and changes the qty to 2. My question is, Is their anyway to make each submission a separate item. you can see it here flags.php
dbotdesigns379943
got it sorted myself
theres a line in
// WA eCart AddToCart
$ATC_AddIfIn = 0;
i set it to
$ATC_AddIfIn = 2;
and it works like a charm now each time you hit add to cart it makes a seperate entry (bad news is it makes an new entry even if the options match)
The way to do it is to update your cart and mark options as a unique column. Leave add if in set to 0.
