CSS - Problem
Thread begun 4/20/2010 8:06 am by tonygmg362159 | Last modified 4/28/2010 6:43 am by Jason Byrnes | 4011 views | 6 replies |
tonygmg362159
CSS - Problem
Hi All,
I am trying to do a j-query pop out div which works fine but the problem is the css you have to display:none; for the window now when you do this the map only displays half / quater of the map, yet when you take the css display:none; out it the map works fine but the j-query box doesnt display right as it shows the map soon as the page is completely refreshed. I have attached the source code i am working on.
<html xmlns="http://www.w3.org/1999/xhtml" xmlns:v="urn:schemas-microsoft-com:vml">
<head>
<title>Test div with j-query</title>
<script type="text/javascript" src="http://code.jquery.com/jquery-latest.pack.js"></script>
<script>
$(document).ready(function() {
//select all the a tag with name equal to modal
$('a[name=modal]').click(function(e) {
//Cancel the link behavior
e.preventDefault();
//Get the A tag
var id = $(this).attr('href');
//Get the screen height and width
var maskHeight = $(document).height();
var maskWidth = $(window).width();
//Set heigth and width to mask to fill up the whole screen
$('#mask').css({'width':maskWidth,'height':maskHeight});
//transition effect
$('#mask').fadeIn(1000);
$('#mask').fadeTo("slow",0.8);
//Get the window height and width
var winH = $(window).height();
var winW = $(window).width();
//Set the popup window to center
$(id).css('top', winH/2-$(id).height()/2);
$(id).css('left', winW/2-$(id).width()/2);
//transition effect
$(id).fadeIn(3000);
//if close button is clicked
$('.window .close').click(function (e) {
e.preventDefault();
$('#mask').hide();
$('.window').hide();
//if mask is clicked
$('#mask').click(function () {
$(this).hide();
</script>
<style>
body {
font-family:verdana;
font-size:15px;
a {color:#333; text-decoration:none}
a:hover {color:#ccc; text-decoration:none}
#mask {
position:absolute;
left:0;
top:0;
z-index:9000;
background-color:#000;
display:none;
#boxes .window {
position:absolute;
left:0;
top:0;
width:440px;
height:200px;
z-index:9999;
padding:20px;
display:none;
#boxes #dialog {
width:780px;
height:500px;
padding:10px;
background-color:#ffffff;
padding-left:100px;
padding-top:25px;
margin-right:auto;
margin-top:20px;
</style>
<script type="text/javascript" src="google_javascript/wagmp_map_1.js">/*wagmp*/</script>
<script type="text/javascript" src="http://maps.google.com/maps?file=api&v=2&key=ABQIAAAAz3QqxAzB2hGbt6H7NWJP6xRIHJbIy01oCWeKCM9kpE13ExYKZRTkswTg9xhL1Ek0xrQo1kjW_z6Rng">/*wagmp*/</script>
</head>
<body>
<ul>
<li><a href="#dialog" name="modal">Simple Window Modal</a></li>
</ul>
<div id="boxes">
<div id="dialog" class="window">
<p>
<a href="#"class="close"/>Close it</a></p>
<p>&nbsp;</p>
<div id="wagmp_map_1" style="width: 700px; height: 400px;"></div>
</div>
<!-- Mask to cover the whole screen -->
<div id="mask"></div>
</div>
<script type="text/javascript" src="google_javascript/wagmp_maps.js">/*wagmp*/</script></body>
</html>
this is more a javascript problem than a css problem.
the issue is that the map is created when the page loads. It is created using the height and width of the containing object at load time, your jQuery is changing that height and width so the map is not created to the correct dimensions.
to fix the problem, find the following line of code in the google_javascript/wagmp_map_1.js file:
var map = new GMap2(document.getElementById('wagmp_map_1'));
and change it to:
var mapElem = document.getElementById('wagmp_map_1');
var mapWidth = mapElem.style.width;
var mapHeight = mapElem.style.height;
var map = new GMap2(document.getElementById('wagmp_map_1'),{size:new GSize(mapWidth.replace('px',''),mapHeight.replace('px',''))});
tonygmg362159
It works Thanks :D
tonygmg362159
Jason a question,
my map still doesnt display in IE 7 and sometimes in IE 8 it takes a couple of attempts to display the map any idea's?
please post a link where i could see the problem to investigate the cause.
tonygmg362159
Hi jason, link can be found here:
WT_Dates.php
click on the left where it says:
Sunday 18th July - Puppy am (incorporating young handlers)
login.php
