Can i use database alias with dataasist?
Thread begun 4/19/2010 5:17 pm by aaron5263 | Last modified 4/22/2010 6:27 am by Jason Byrnes | 2237 views | 5 replies |
aaron5263
will dataassist 2.0.6 recognize database alias names? It seems like it does not recognize them.
No, it will not recognize alias names, only the original names that are assigned in the table.
aaron5263
ok how do i get around this problem because im getting an error saying
Ambiguous column name. i have several tables joined together via left joins.
i made the mistake of naming column names the same in 2 tables.
in the code that references the column name, you need to add the table name.
Send a copy of your page and I will show an example of what needs to be changed.
aaron5263
like this ?
'comparison list additions
WADbSearch1_whereClause=BuildFilterString("products.master_cat","" & cStr( Request.QueryString("gauges") ) & "","","=",0,WADbSearch1_wildCard,WADbSearch1_dateSeparator,WADbSearch1_whereClause)
WADbSearch1_whereClause=BuildFilterString("products.catagory","" & cStr( Request.QueryString("auto") ) & "","AND","=",0,WADbSearch1_wildCard,WADbSearch1_dateSeparator,WADbSearch1_whereClause)
WADbSearch1_whereClause=BuildFilterString("products.sub_cat","" & cStr( Request.QueryString("gauge_size") ) & "","AND","=",0,WADbSearch1_wildCard,WADbSearch1_dateSeparator,WADbSearch1_whereClause)
WADbSearch1_whereClause=BuildFilterString("products.sub_cat_2","" & cStr( Request.QueryString("gauge_type") ) & "","AND","=",0,WADbSearch1_wildCard,WADbSearch1_dateSeparator,WADbSearch1_whereClause)
my table is products so i added this to the query and it seems to work. Anywhere else i need to change it? would be nice if next release 2.0.7 just included the table name in front of the query section of code.
that should be all that needs to change.
I will add a feature request.
