Diable the "delete" if in use?
Thread begun 4/19/2010 3:33 pm by MikeH | Last modified 4/20/2010 6:50 am by MikeH | 3475 views | 7 replies |
MikeH
Hi
I have a DA results page with a "delete" record button as setup with the wizard.
The results are showing the BRANDS I have (these brands have an Id column)
The Id column is linked to the BrandsId in the Product Table.
Is there a way to disable the delete option if a product is using that Brand?
Thanks in advance
Mike
CraigRBeta Tester
what you need to do is have a recordset on your page which will return rows if the brandsid is present.
you can then use a dreamweaver server behavior to show 'content' if your recordset is not empty.
follow this with a dreamweaver server behavior to show 'other content' if your recordset is empty.
MikeH
Hi
Thanks for the reply.
Im ok with the show region if(if not) just a bit stuck on geting the second recrdset to return rows depending on the first recordsets brandid.
Obviously the first set is in a repeat region to show all the brands my second set is not in that region so it only reads a first record.
Any ideas?
CraigRBeta Tester
i presume the first recordset is filtered by brandid from a form/url/session variable ?
use this same variable as your filter for your second recordset.
if i am missing the mark here, can you post a link to the pages ?
MikeH
Hi Craig
The first recordset is created by the DA Wizard so it the admin results page (BTW sites on a local testing server so cannot show page).
Basically the first sets results are disaplayed in a repeat region of a table:
ID | Brand Name | Logo | {Edit} {delete}
Thats repeated until the whole list is shown.
I would have liked that a check would be done to the first RS to check if a product in the second RS is using that brand so if it is the {delete} button would not be available so something in use by a product cannot be removed.
I hope that makes it clearer?
Mike
MikeH
Hi
just an update. I have managed to do it with a bit of manual php and a really useful library called: good_query_ library.
Thanks for your help though.
Mike
CraigRBeta Tester
i have looked back at something i did with DA recently,
what i had was 2 sets of results pages (and associated insert, edit and delete pages), one for items and one for itemcategories.
with the wizard, i created a set of pages for items and a set for itemcategories.
what i wanted to ensure was that i couldn't delete an itemcategory if it had items associated with it.
in my itemcategory result page, i can open the delete itemcategory page
on this page i use the itemcategoryid passed as a url variable from the results page to filter my recordset, (basically select * from tblitemcategory where itemcategoryid = urlvariable)
is this what you're after ?
**ok, never mind, you sorted it whilst i was typing this**
MikeH
Hi
Yes thats the same idea.
With what I have done is literally the delete button is not there for any Brand (in your case Category) that has an associated item.
Mike
