PayPal checkout not working
Thread begun 4/19/2010 12:01 pm by sales401386 | Last modified 4/21/2010 6:10 pm by Jimmy Wu | 4641 views | 9 replies |
sales401386
I have set up my site with all the API information required from PayPal but any time that a transaction is made, the customer receives this error message "Transaction Not Completed
We're sorry
Your transaction could not be completed. Either your credit card information or billing address has problems and cannot be processed
Please return to checkout and try again."
What is going wrong? Any help would be greatly appreciated.
i.edwards384429
update
Hi
try going into the admin and ensure that in the tabs
site is not set to "test mode" and in the tab payment information "Sandbox" is not selected.
If that does not cure it try altering the following code
function WA_PP_ECO_CallSOAP($sXML, $useSB) {
$soapObj = new WAPPECOSOAPObject;
$soapObj->soapURL = "https://api-3t.paypal.com/2.0/";
if ($useSB) {
$soapObj->soapURL = "https://api-3t.sandbox.paypal.com/2.0/";
I changed them to this (I commented out the PayPal sandbox URL, and the URL is now universally set to the PayPal non-sandbox URL):
if ($useSB) {
// $soapObj->soapURL = "https://api-3t.sandbox.paypal.com/2.0/";
HTH
Ian
sales401386
I saw that in a search earlier, tried it, but it did not work. Any other suggestions?
Jimmy Wu
to be able to tell the reason for the failure, we need to know the full response from the gateway. add the following code to your failure page to output the full request and full response from the gateway, this will help us in determining the cause of the problem:
if(!session_id()) session_start();
 if(
$WAGLOBAL_Gateway == 1 ) {
     echo
"<p>Direct Pay: <br />";
     echo
"Full Request: ".(isset($_SESSION["PP_DirectPayment_postedValues"])?htmlentities($_SESSION["PP_DirectPayment_postedValues"]):"n/a")."<br />";
     echo
"Full Response: ".(isset($_SESSION["PP_DirectPayment"])?htmlentities($_SESSION["PP_DirectPayment"]):"n/a")."<br /></p>";
     echo
"<p>Express Authorize <br />";
     echo
"Full Request: ".(isset($_SESSION["ECO_Auth_Request"])?htmlentities($_SESSION["ECO_Auth_Request"]):"n/a")."<br />";
     echo
"Full Response: ".(isset($_SESSION["ECO_Auth_Result"])?htmlentities($_SESSION["ECO_Auth_Result"]):"n/a")."<br />";
     echo
"<p>Express Process: <br />";
     echo
"Full Request: ".(isset($_SESSION["ECO_Process_Request"])?htmlentities($_SESSION["ECO_Process_Request"]):"n/a")."<br />";
     echo
"Full Response: ".(isset($_SESSION["ECO_Process_Result"])?htmlentities($_SESSION["ECO_Process_Result"]):"n/a")."<br /></p>";
 if(
$WAGLOBAL_Gateway == 2) {
     echo
"<p>Auth Net: <br />";
     echo
"Full Request: ".(isset($_SESSION['WAAuthNet_postedValues'])?htmlentities($_SESSION['WAAuthNet_postedValues']):"n/a")."<br />";
     echo
"Full Response: ".(isset($_SESSION['WAAuthNet'])?htmlentities($_SESSION['WAAuthNet']):"n/a")."<br /></p>";
  if(
$WAGLOBAL_Gateway == 3 ) {
     echo
"<p>Express Authorize: <br />";
     echo
     echo
"Full Response: ".(isset($_SESSION["ECO_Auth_Result"])?htmlentities($_SESSION["ECO_Auth_Result"]):"n/a")."<br /></p>";
     echo
     echo
     echo
 if(
$WAGLOBAL_Shipping == 1) {
     echo
"<p>UPS: <br />";
     echo
"Full Request: ".(isset($_SESSION["WA_Store_Cart_UPS_FullRequest"])?htmlentities($_SESSION["WA_Store_Cart_UPS_FullRequest"]):"n/a")."<br />";
     echo
"Full Response: ".(isset($_SESSION["WA_Store_Cart_UPS_FullResponse"])?htmlentities($_SESSION["WA_Store_Cart_UPS_FullResponse"]):"n/a")."<br /></p>";
 if(
$WAGLOBAL_Shipping == 2) {
     echo
"<p>FedEX: <br />";
     echo
"Full Request: ".(isset($_SESSION["WA_Store_Cart_FedEx_FullRequest"])?htmlentities($_SESSION["WA_Store_Cart_FedEx_FullRequest"]):"n/a")."<br />";
     echo
"Full Response: ".(isset($_SESSION["WA_Store_Cart_FedEx_FullResponse"])?htmlentities($_SESSION["WA_Store_Cart_FedEx_FullResponse"]):"n/a")."<br /></p>";
 if(
$WAGLOBAL_Shipping == 3) {
     echo
"<p>USPS: <br />";
     echo
"Full Request: ".(isset($_SESSION["WA_Store_Cart_USPS_FullRequest"])?htmlentities($_SESSION["WA_Store_Cart_USPS_FullRequest"]):"n/a")."<br />";
     echo
"Full Response: ".(isset($_SESSION["WA_Store_Cart_USPS_FullResponse"])?htmlentities($_SESSION["WA_Store_Cart_USPS_FullResponse"]):"n/a")."<br /></p>";
NOTE:
The full request and full response will contain sensitive information like credit card number or paypal credentials, please block these values out before posting.
i.edwards384429
update
Hi
What have you modified in the site?
MY next step would be to
1. backup my work to date.
2. Drop an sql file of the database
3. Delete the database
4. Delete the web site.
5. I'd upload a fresh copy of PS3
6. Run the install program
7. When you reach the admin stage input the paypal express details
8. Create and item costing $1
9. register an email address and buy that item.
You have then eliminated all your work and are left with a problem either with paypal or the WA code. If it still does not work then there is code on the forum you can add to pages for fault finding but it is essential that you work with a clean installation.
Let us know how you get on
HTH
Ian
sales401386
Originally Said By: i.edwards384429
  Hi
HTH
Ian
I haven't changed anything on the site except added the information to build it and the required PayPal and UPS information. I tried adding the code above to the "pp_checkout_failure.php" page but it showed nothing except the same error message. I copied and pasted it in both the beginning and the end of the code presently on the page.
Jimmy Wu
Did you make sure to upload the page after making the changes? Are you checking out using express checkout or regular checkout? What page did you add the code to?
sales401386
Originally Said By: Jimmy Wu
Yes I did.
Both.
As stated above, the "pp_checkout_failure.php" page (in the body as was stated in another post).
With all the different posts here about the same issue, it appears as though the software has bugs. I purchased this for the ease of setting up my website but it has not been very easy (or quick) to get any resolution to my problem. If this can't be resolved, please contact me so I can get a refund.
Jimmy Wu
I have opened a backend ticket to look into this issue further with you. To check your backend tickets log in to your account at www.webassist.com and check your support history.
sales401386
According to PayPal, the first API cal is going through to them and responded to but nothing happens after that. He confirmed that I have the Payment Information boxes filled out properly for my PayPal. I hope to get this resolved soon as the whole reason for buying a pre-made site was I don't have the web making capabilities or knowledge.
