coupon error
Thread begun 4/19/2010 10:28 am by muddysmurf | Last modified 4/26/2010 3:07 pm by Jimmy Wu | 3018 views | 7 replies |
muddysmurf
coupon error
I'm trying to add a discount to a specific product, but when I click on insert, it goes to an error page and says:
/store/Admin/products_Search.php?InProcess=AddToCoupon
like that section isn't there. What could be the cause of this?
Jimmy Wu
Its possible that the page is actually not there. Make sure that you have uploaded the products_search.php file to the Admin directory within your store.
What does the error page say? Is it a 404 page not found error or some other error?
muddysmurf
I thought the same thing when it happened, but that page is there. I've sent it up twice just in case.
I believe that is a 404 page error.
Jimmy Wu
If you go to the Products menu and click on the Find Product, does it link you to the Products_Search.php file correctly or does that also go to the wrong place?
muddysmurf
Everything searches fine. I just tried it in the actual store that the customer would see, and in the admin section.
Jimmy Wu
I have opened a backend ticket so we can take a look into this issue in more detail. To check this ticket, log in to your account at www.webassist.com and check your support history.
email377288
Hi, I was also having this problem.
On the coupons_Update.php page I got error 404 when I clicked on the edit products button. The page is looking for the URL products_Search.php?InProcess=AddToCoupon&CouponID=9
To fix this error edit coupons_Update.php and search for products_Search and replace with Products_Search. (capital P for products). Save the file, upload to server and you should be sweet.
EDIT: Apply same fix to coupons_Detail.php as it is incorrect there as well.
Cheers
Jimmy Wu
That is the fix that I found as well, just wanted to wait for the user to confirm that it worked for them to post it up on the forum.
