Registration page not working
Thread begun 4/16/2010 11:58 am by gjdunn405023 | Last modified 4/20/2010 10:11 am by gjdunn405023 | 4740 views | 12 replies |
gjdunn405023
More problems.
After setting up a Registration page, removing some of the fields from the page and from the database; I tested the page and found that the information did not transfer to the database, and more curiously, the information entered into the fields remained visible after the "Register" button was triggered, and even worse, it remained visible after quitting the browser and returning to the Registration page.
Any help appreciated.
line 50 - 69 of the registration page performs validation on the form fields:
if ($_SERVER["REQUEST_METHOD"] == "POST")  {
$WAFV_Redirect = "";
$_SESSION['WAVT_usersRegistration_Errors'] = "";
  if (
$WAFV_Redirect == "")  {
$WAFV_Redirect = $_SERVER["PHP_SELF"];
$WAFV_Errors = "";
$WAFV_Errors .= WAValidateNM($totalRows_CheckRepeat . "",-1,0,"",",.",true,1);
$WAFV_Errors .= WAValidateEM(((isset($_POST["UserEmail"]))?$_POST["UserEmail"]:"") . "",true,2);
$WAFV_Errors .= WAValidateEL(((isset($_POST["UserPassword"]))?$_POST["UserPassword"]:"") . "",6,50,true,3);
$WAFV_Errors .= WAValidateRX(((isset($_POST["UserPassword"]))?$_POST["UserPassword"]:"") . "","/[0-9]/",true,4);
$WAFV_Errors .= WAValidateRX(((isset($_POST["UserPassword"]))?$_POST["UserPassword"]:"") . "","/[a-z,A-Z]/",true,5);
$WAFV_Errors .= WAValidateLE(((isset($_POST["UserPassword"]))?$_POST["UserPassword"]:"") . "",((isset($_POST["UserPassword2"]))?$_POST["UserPassword2"]:"") . "",false,6);
$WAFV_Errors .= WAValidateLE(((isset($_POST["Security_code"]))?strtolower($_POST["Security_code"]):"") . "",((isset($_SESSION["captcha_1"]))?strtolower($_SESSION["captcha_1"]):"") . "",true,7);
$WAFV_Errors .= WAValidateLE(((isset($_POST["Security_question"]))?strtolower($_POST["Security_question"]):"") . "",((isset($_SESSION["random_answer"]))?strtolower($_SESSION["random_answer"]):"") . "",true,8);
$WAFV_Errors .= WAValidateRX(((isset($_POST["addblock"]))?$_POST["addblock"]:"") . "","/^$/i",false,9);
$WAFV_Errors .= WAValidateRX(((isset($_POST["secondblock"]))?$_POST["secondblock"]:"") . "","/^$/i",false,10);
$WAFV_Errors .= WAValidateRQ(((isset($_POST["UserFirstName"]))?$_POST["UserFirstName"]:"") . "",true,11);
$WAFV_Errors .= WAValidateRQ(((isset($_POST["UserLastName"]))?$_POST["UserLastName"]:"") . "",true,12);
$WAFV_Errors .= WAValidatePN(((isset($_POST["UserPhone"]))?$_POST["UserPhone"]:"") . "",false,true,true,13);
$WAFV_Errors .= WAValidatePN(((isset($_POST["UserFax"]))?$_POST["UserFax"]:"") . "",false,true,false,14);
$WAFV_Errors .= WAValidateRQ(((isset($_POST["UserAddress"]))?$_POST["UserAddress"]:"") . "",true,15);
$WAFV_Errors .= WAValidateRQ(((isset($_POST["UserCity"]))?$_POST["UserCity"]:"") . "",true,16);
$WAFV_Errors .= WAValidateRQ(((isset($_POST["UserState"]))?$_POST["UserState"]:"") . "",false,17);
$WAFV_Errors .= WAValidateZC(((isset($_POST["UserZip"]))?$_POST["UserZip"]:"") . "",true,true,true,true,true,18);
$WAFV_Errors .= WAValidateRQ(((isset($_POST["UserCountry"]))?$_POST["UserCountry"]:"") . "",true,19);
  if (
$WAFV_Errors != "")  {
PostResult($WAFV_Redirect,$WAFV_Errors,"usersRegistration");
if you delete a form field, you will need to also delete the validation for that form field.
for example, if you delete the phone number form element, you will need to delete the following validation line:
gjdunn405023
After deleting the indicated code, the following errors occurred:
Warning: mysql_select_db(): supplied argument is not a valid MySQL-Link resource in /Library/WebServer/Documents/worldmix/UserRegistration100/users_Registration.php on line 100
Warning: mysql_query(): supplied argument is not a valid MySQL-Link resource in /Library/WebServer/Documents/worldmix/UserRegistration100/users_Registration.php on line 104
please send a copy of the page so I can see the code.
gjdunn405023
I need to be able to see the php code.
Please compress the page into a zip archive and attach the zip file to your reply.
gjdunn405023
As requested.
you have removed the line to connect to the connections/localhost.php file.
Add the following at line 1:
<?php require_once('Connections/localhost.php'); ?>
make sure to edit the Connections/localhost.php file with the correct information to connect to your database.
gjdunn405023
Thank you for the response.
When I first set up the db files, I chose an existing mysql db connection which is shown in Line 7. It appears in the Dreamweaver Application windows correctly with the appropriate tables, and in the root Connections folder.
After adding "Connections/localhost.php" in line 1, and trying to register, I get "Unknown column 'UserCity' in 'field list'".
Thanks for your patience.
you must use the localhost connection with the User registration solution pack.
Also, you will need to use the users table that is shipped with the user registration solution pack.
In the database folder, there is a users.sql file that can be used to create the users table. see the following for instructions:
ursp_importing_sql.pdf
