TopMargin in CSS Sculptor layout
Thread begun 4/16/2010 6:53 am by PeterL | Last modified 4/20/2010 6:07 pm by Eric Mittman | 3258 views | 5 replies |
PeterL
i'am not able to set a topmargin in CSS sculptor layout!?
Cannot find the reason for that.
Can anybody help me with this problem?
PeterL
find out that if i delete the css rule #divOuterWrapper and define a new one everything works fine
PeterL
In regards to making this update within the Sculptor interface could you post back with a little more detail and perhaps some screens shots of the area you are trying to update and cannot. There might be another way of doing this or there could be an issue in the product that we are not aware of. Please post back with the details so we can look into this further.
PeterL
Hi Eric,
send you a few screen shots that should make the problem clear
It looks like you are doing this correctly. When you choose your layout you should edit the css. In the box tab select the outer wrapper, then go into the margin and for the top margin enter the amount and make sure to specify a unit. I set the top margin to 200px and it seemed to work fine for me. Looking at the screen shots it seems that you may have missed the px part, make sure that you select it from the select list after entering the value.
PeterL
Hi Eric,
problem solved; forgot indeed to select the outerwrapper.........:D
Thanks again,
Peter
Good to hear, let us know if you have any other questions.
