customising for Australian Site
Thread begun 4/16/2010 1:15 am by welcomcat385026 | Last modified 4/19/2010 3:07 pm by Eric Mittman | 3303 views | 4 replies |
welcomcat385026
I followed your instruction to change currency parameter, however on paypal confirmation page $USD still comes up and I'm not sure paypal is doing transaction in AUD or USD.
Also checkout page, even if I choose Country "Australia", State-province is still American, do I have to program manually?
On Paypal transaction page the company header which has a paypal business A/C comes up, can I customise it to the actual business name, in other words, the site name?
It seems lots of work involved if the site is not inside US. Regards,
welcomcat385026
attachment didn't go with my post
Australian site,
For the states select list it is static, so it has the same entries regardless of the country that is selected. If you do not want the US states in there you can just remove them, if you need to add Australian territories you will need to add them manually to the list.
As for the currency that you see on PayPal this might be due to an account setting. You should check in your profile to ensure that you have it setup to work with AUD instead of USD. You are passing the currency code correctly it seems, did you update the checkout and pp_confirm pages both?
For the name that you see in the header of your PayPal page you should be able to customize the look of these pages, here is a link to the PayPal page that discusses making these changes:
cowp_summary-outside
welcomcat385026
Currency Code working well
Thank you, everything is working well. The problem was confirm.php wasn't updated.
One more thing to ask: I was customising paypal payment page. The header image doesn't show up. Maybe URL is wrong. JPG is sitting in my site file exposed like index.html. (-----.jpg) Is this correct? Best regards,
If you can browse to the image and see it with the URL then it should be correct. Have you also checked using an https URL? You might need to provide the image to PayPal via a secure link, meaning that the URL should have https instead of just http.
