ASP Options on Category page
Thread begun 4/15/2010 8:23 pm by bjgarner241692 | Last modified 4/20/2010 8:23 am by bjgarner241692 | 2806 views | 4 replies |
bjgarner241692
I have a site where some, but not all products have options.
The options vary by product.
There is no price associated with the options. They are things such as size or colour.
I have a working Category page, on which I have a Buy now button leading to a Product Details page. On the Product Details Page, I am able to call up the options by linking the tables in the RecordSet. Adding to cart at this level is no problem. Everything works fine.
What I would like to achieve, is to eliminate the Product Details page but I cannot get the options to display properly on the Category Page.
I can envision the resolution, but I cannot code it.
What I need is a second recordset for options that would look something like this.
rsOptions
SELECT *
FROM options
WHERE prodname = param
param = prodname from rsProds
I've tried doing it with a hidden form and field but that failed and I've tried calling the rsProds.prodname field directly but I cannot get the syntax to work.
If I could get rsOptions to work, the rest of it is easy. I can show or hide the options dropdown based on whether there is a value in rsOptions.
Can this be done?
the key for making this work is to move the rsProds recordset into the repeat region that is used to display the product.
Send a copy of your page, and I can help with the coding.
bjgarner241692
I've pretty much undone what I had attempted so I have nothing to send at present.
Do you just mean to put the actual code, defining the recordset, in the repeat region rather than before the <HEAD>?
yes, as well as setting the filtering options to use the value from the record set that is creating the repeat region.
The idea is that each time a record is displayed, the options record set needs to be recreated form the current record.
by nesting the record set in the repeat region, you can filter it on the current record to get the options pertinent to that product.
bjgarner241692
Thank you, that worked perfectly
