universal email
Thread begun 4/15/2010 7:53 pm by david331670 | Last modified 4/20/2010 8:08 am by Jason Byrnes | 3665 views | 7 replies |
david331670
universal email
problem with my online shopping cart.
When I confirm details and submit to paypal, the purchase is completed, UE is to send email of details. However I get a syntax error from the WAUE_confirm_7.php file. Error reads "Parse error: syntax error, unexpected '}' in /usr/home/spect7/www/htdocs/WA_Universal_Email/WAUE_confirm_7.php on line 205"
Lines 204 to 209 are:
//WA eCart Show If Middle
} -(this is row 205)
else {
$MailBody = $MailBody . "<table><tr><td>The cart is empty</td></tr></table>";
//WA eCart Show If End
This syntax error stops the success page from being sent or loaded and the user doesnt know if the transaction has gone thru.
I have recreated this file a number of times and I still get the same error.
I have removed the offending bracket but get another error.
I have attached the WAUE_confirm.php file zipd
This is causing many problems at the moment
Can you please help
Thank you.
change line 61 - 62:
$MailBody = $MailBody . "                \r\n";
$MailBody = $MailBody . "                    <td style=\"padding:10px 7px 10px 7px; vertical-align:top; \">\r\n";
while (!$Spectrum_online->EOF())      {
david331670
universal email
I have changed the item as shown
I now have another error
Parse error: syntax error, unexpected T_VARIABLE in /usr/home/spect7/www/htdocs/WA_Universal_Email/WAUE_confirm_7.php on line 61
still does not work.
david331670
universal email
I have updated to universal email 4
I have recreated all the email and changed all the links to the newly generated folder and files. It has taken me most of the day but I now get a successful transaction, however the email sent is a "0" That all, just a "0"
I have set up the pages as before ( all this used to work before I updated to ecart 5)
I get the correct to and from email, and it sends but the content is "0"
The source code of the email has
"--WAMULTIBREAKWA
Content-Type: text/plain
Content-Transfer-Encoding: 8bit"
The mail_php.php file has these in the source code.
copy zpd The body format is very similar to the older file fron UEVer3, I dont know if it not not correct but I dont know how to edit the file the files to include the html body.
Can you help again please.
Regards David
david331670
Ver 4 UE
I have managed to fix the previous problems. I gleaned enough from other support items and a bit of trial and error.
However whenever I try to edit the html I need to go and remove all the offending code all over again. Not happy. I can only assume it is was for a purpose for all this extra stuff (less is more from my perspective and why you need to remove it to enable it to work is puzzeling) and I await the bug fix.
So the email now works sending the order by email from the confirm .php page, it however does not include the order number in the email but it does in the success.php page.
I assume the email is sent as soon as clicking on posting or clicking the "checkout button" on the confirm.php page.
I am not sure when the order number is retrieved but I think the email is sent prior to this?? and as such does not have an order number yet.
How can I get the order number to be posted with the email??
You continued help id appreciated. I cant help my sarcasm though, it slips out every so often.
Regards
David
the order number is generated by the store order summary server behavior. The Universal Email Code must be after the store order summary code for the order number to appear in the email, please send a copy of your page so I can examine the code.
david331670
UE
My guess would be to place the:
<?php require_once("webassist/email/mail_php.php"); ?>
<?php require_once("webassist/email/mailformatting_php.php"); ?>
if (!isset($_SESSION))session_start();
$_SESSION[$EmailRef."_Total"] = 0;
$_SESSION[$EmailRef."_Index"] = 0;
$_SESSION[$EmailRef."_Remaining"] = 0;
session_commit();
session_start();
if ($GoToPage!="") {
header("Location: ".$GoToPage);
After line 805, but not sure if inside table or outside table but inside form.
Just a guess but from what you said the only place I can think of.
David
the universal email code is lines 241 - 328
the Store Order Summary code block is lines 329 - 389
The universal Email code block needs to be moved to the end of line 389 so it is after the store order summary code block
