success page ok, no Authorize.net transaction record
Thread begun 4/15/2010 3:01 pm by lilisosad391796 | Last modified 4/21/2010 5:44 pm by Eric Mittman | 4029 views | 7 replies |
lilisosad391796
Hi, I've just setup a store for my client and all the checkout pages are working fine, she got the confirmation email from the her website but not getting any transaction reports from Authorize.net according to the client.
She even got an email with the transaction details:
************* TEST MODE *************
========= GENERAL INFORMATION =========
Merchant : AZUL CONSERVATION PRODUCT
Date/Time : 15-Apr-2010 02:33:52 PM
Transaction ID : 0
========= ORDER INFORMATION =========
Invoice Number : 6bb4e0b0610bcdb283b7
Description : 1 Mini Sand Shower Timer- 4 minute (15)
Total : US $6.09
Tax Exempt : No
Payment Method : Visa
billing address and shipping address are showing fine.
I ran the store in test mode before i configured everything and it was working fine.
the Local Checkout Server behavior in the confirm.php page has the correct settings, we doubled checked the login and transaction key with them and still nothing. Is there something that I'm forgetting to configure or does she have to check directly with Auth.net??
thanks!
If this is from a message that you are getting currently then it looks like you still have it in test mode. There are two places where test mode is set in PowerStore if you use Authorize.net. In the site settings is the test mode check box, make sure that this is not checked. There is also a test mode available in the payment information tab when use Authorize.net. Make sure that this box is unchecked, it looks like this is the one that is causing the issue since the site settings test mode would not produce a message from Authorize.net.
lilisosad391796
I am using Ecart, should I look into the server behaviors to turn the test mode off?
Again thanks for the quick response.
Sorry about that, yes, you should check on your Authorize.NET server behavior. The value that makes it go into text mode is x_test_request, in the code it looks like this:
$AuthNet_required[0][$nextIndex] = "x_test_request";
When viewing the code it is the line that comes just after this that tells it to use the testing server. You need to make sure that this setting is set to false to make the transactions live and record with Authorize.NET.
lilisosad391796
Default success page ok, no Authorize.net transaction record
Hi again, the setting is now false and it should be working.
my client is concerned about the form validation. Whats the best way to do this?
I personally think that server side validations are best. You can apply server validations to the checkout form with CSS Form Builders server validations or by using the validation toolkit, whichever one you have.
lilisosad391796
css form validation not showing
Hi again, I applied server validations to the checkout form that I already had configured in Ecart using the wizard. I uploaded the php file and the scripts but i'ts not showing any error messages when I intentionally leave a field blank or type the wrong information.
Thanks as always for the advice.
Lili Sosa.
You will need to setup the server validations in two parts. There is the validation itself, for this you apply the Server Behaviors > WA Validation Toolkit > Server Validations. Make sure to set the failed redirect to the checkout page to stop it from proceeding.
Once you have configured the server validations you will need to craft your error messages. For this just put in some text next to a form element then highlight the text and go to WA Validation Toolkit > Validation Show If. Then select the corresponding server validation that you would like to trigger the error message in the 'if validations fail' area.
If you have not used the server validations before I would suggest that you add it to a single form element first, then apply the validation show if for the error message and test it out. This should get you going.
