Powerstore with real products AND affiliate products
Thread begun 4/15/2010 12:22 pm by larsentim278054 | Last modified 4/15/2010 1:11 pm by Jimmy Wu | 1244 views | 1 replies |
larsentim278054
Is is possible to have Powerstore show products where it will go through the checkout process (with credit cards and payment gateways) but also have products that just click over to the other company (I'm an affiliate). I know it's possible either way, but is it possible to have BOTH on the same store?
How do I set certain products to just send them to another site instead of to the shopping cart? (so there would be different quantities or options and each option would go to a different link).
How can I set this up?
Jimmy Wu
This would require some custom coding and modifications. I can give you an outline on how you would do this, but you will have to implement it yourself. You would need to add a new column in the database to store whether a product is in house or an affiliate. One way you can do this is to store the url in the database for the affiliate and don't store anything when its not an affiliate. Then you could either set this value directly in the database or create an interface to set it. Then on the product detail page, you'd have to put in a check on whether the product is affiliate or not and display the correct button accordingly.
