Dreamweaver CS4 Site Import fails JavaScript error at line 393
Thread begun 4/14/2010 6:44 pm by h.fingerhut405448 | Last modified 4/19/2010 1:08 pm by Jason Byrnes | 3958 views | 5 replies |
h.fingerhut405448
Tried to run Site Import 3 with Dreamweaver CS4 on a PC runing Window 7 x64
Attached Dreamweaver pop up error attached says that there is a JavaScript error while executing timer in WA_SiteTools.htm at line 393
try deleting the Dreamweaver cache file from the users configuration folder:
h.fingerhut405448
Same Result
Getting exactly the same results after deleting the file
can you send a copy of the WAImportLog.txt file that is created in the import directory.
h.fingerhut405448
WAImportLog attached
Here is the log
login.php
