Email content from select list label
Thread begun 4/13/2010 11:57 pm by Daryl | Last modified 4/14/2010 7:44 am by Jason Byrnes | 1143 views | 1 replies |
DarylBeta Tester
I have created a contact form where you select a department from a select list.
In the email I want to personalise it with the name of the department that is being contacted, however the select list insert only inserts the value and not the label.
Is there a way to achieve this?
you can use javascript to populate a hidden form element with the label of the selected item in the select list, then output the value of the hidden element.
here is an example:
<form id="form1" name="form1" method="post" action="" onSubmit="document.form1.hiddenField.value = document.form1.select[document.form1.select.selectedIndex].text">
<p>
<select name="select" id="select">
<option value="1">one</option>
<option value="2">two</option>
<option value="3">three</option>
</select>
</p>
<p>
<input type="hidden" name="hiddenField" id="hiddenField" />
</p>
<p>
<input type="submit" name="button" id="button" value="Submit" />
</p>
</form>
