I can't edit my menu
Thread begun 4/13/2010 12:19 pm by mrobben375515 | Last modified 4/14/2010 10:07 am by mrobben375515 | 2133 views | 2 replies |
mrobben375515
CSS Menu Writer has been working fine until today...I tried to change the links and the design and keep getting these error messages when I hit "Finish"...
While executing onResize in WA_SiteTools_Progress.htm, the following Javascript errors occured:
In file "WA_SiteTools_Progress":
refreshUI is not defined
and then right after i pushed ok on that I got another error
Error generating menu (wa.generate.menu):
TypeError: MM.WA_createProcessingObject is not a function
What is going on? I have no control over my menu now.
neilo
Hiya,
Usually, simply deleting the WinFileCache.dat or MacFileCache.dat (depending on what your OS is) should solve that problem. It will not adversely affect anything in any way, and is the first thing to try to resolve your problem.
View the WebAssist Technotes if you need guidance.
mrobben375515
perfect..thanks
