Lots of warning messages after clicking the confirm button
Thread begun 4/13/2010 10:15 am by pmait97856 | Last modified 4/20/2010 1:41 pm by Jason Byrnes | 3382 views | 5 replies |
pmait97856
I am testing eCart 5 and have followed the user guide step by step.
Everything seems to work as expected until I click the confirm button on the confirm page.
That's when I get all these messages:
Warning: Division by zero in /home3/paul5b5c/public_html/crowlane/customerCentre/confirm.php on line 37
Warning: Division by zero in /home3/paul5b5c/public_html/crowlane/customerCentre/confirm.php on line 38
Warning: Division by zero in /home3/paul5b5c/public_html/crowlane/customerCentre/confirm.php on line 57
Warning: Division by zero in /home3/paul5b5c/public_html/crowlane/customerCentre/confirm.php on line 58
Warning: session_start() [function.session-start]: Cannot send session cookie - headers already sent by (output started at /home3/paul5b5c/public_html/crowlane/customerCentre/confirm.php:37) in /home3/paul5b5c/public_html/crowlane/customerCentre/confirm.php on line 67
Warning: session_start() [function.session-start]: Cannot send session cache limiter - headers already sent (output started at /home3/paul5b5c/public_html/crowlane/customerCentre/confirm.php:37) in /home3/paul5b5c/public_html/crowlane/customerCentre/confirm.php on line 67
Warning: sleep() expects parameter 1 to be long, string given in /home3/paul5b5c/public_html/crowlane/webassist/email/mailformatting_php.php on line 348
Warning: session_start() [function.session-start]: Cannot send session cookie - headers already sent by (output started at /home3/paul5b5c/public_html/crowlane/customerCentre/confirm.php:37) in /home3/paul5b5c/public_html/crowlane/webassist/email/mail_php.php on line 285
Warning: session_start() [function.session-start]: Cannot send session cache limiter - headers already sent (output started at /home3/paul5b5c/public_html/crowlane/customerCentre/confirm.php:37) in /home3/paul5b5c/public_html/crowlane/webassist/email/mail_php.php on line 285
Warning: Division by zero in /home3/paul5b5c/public_html/crowlane/customerCentre/confirm.php on line 76
Warning: session_start() [function.session-start]: Cannot send session cookie - headers already sent by (output started at /home3/paul5b5c/public_html/crowlane/customerCentre/confirm.php:37) in /home3/paul5b5c/public_html/crowlane/customerCentre/confirm.php on line 97
Warning: session_start() [function.session-start]: Cannot send session cache limiter - headers already sent (output started at /home3/paul5b5c/public_html/crowlane/customerCentre/confirm.php:37) in /home3/paul5b5c/public_html/crowlane/customerCentre/confirm.php on line 97
Warning: Cannot modify header information - headers already sent by (output started at /home3/paul5b5c/public_html/crowlane/customerCentre/confirm.php:37) in /home3/paul5b5c/public_html/crowlane/customerCentre/confirm.php on line 344
Although the success page does not load, the database is updated and an email is received.
The only change I made from the user guide is to use db tables: customer_orderdetails and customer_orders instead of orderdetails and orders. (customer_orderdetails and customer_orders are exact copies of the originals).
Can anyone let me know what may be the problem/s and how to solve them.
Also, I really don't need all the columns in the customer_orders table, if I remove some and add a couple I do need, which files do I need to adjust?
Paul
please send a copy of your confirm.php page so I can examine the code.
pmait97856
Confirm page
Hi Jason,
Attached is the confirm page. I had to create a zip of the file.
I did forget to mention that the pages are on a sub domain of my testing server so the path to this file would be:
confirm.php
Could that also be a cause of the problem?
Paul
find the following code:
$BurstSize = undefined;
$BurstTime = undefined;
$WaitTime = undefined;
and change it to:
$BurstSize = 200;
$BurstTime = 1;
$WaitTime = 1;
pmait97856
Thanks, just one more question
Thanks Jason,
That worked, I assume that I need to check for this on all pages that will use email in future.
Just one question related to my original question.
There are a number of columns in the orders table that I do not need and a few new ones that I do.
For instance I do not need:
OrderShipAddress
OrderShipAddress2
OrderCity
OrderState
OrderZip
OrderCountry
OrderFax
OrderShipping
OrderTax
Is it safe to remove these columns or do some of the helper files need them?
I will need to add columns for Cell, TakeoutTime and Date and some others.
Am I correct in assuming that after adding these fields to the checkout page, on the confirm page I will need to delete the session values that I don't need i.e.
if($_SERVER["REQUEST_METHOD"] == "POST") {
$_SESSION["eCartCheckoutForm_fax"] = "".((isset($_POST["fax"]))?$_POST["fax"]:"") ."";
and the hidden fields i.e.
<input type="hidden" name="shipping_fax" id="shipping_fax" value="<?php echo ((isset($_SESSION["eCartCheckoutForm_shipping_fax"]))?$_SESSION["eCartCheckoutForm_shipping_fax"]:"") ?>" />
and replace them with new ones for the new columns?
Regards, Paul
If you are using Shipping rate lookup, it will require the shipping zip and shipping country field, other wise, these fields should not be needed, but I would make a backup of the checkout and confirm pages before deleting them just in case.
as for the session code and hidden form elements, yes, you can delete the ones you don't need, and add new ones for new elements that you add.
