CSS with PowerCMS2
Thread begun 4/12/2010 12:53 pm by robert222776 | Last modified 5/04/2010 10:00 am by neilo | 6344 views | 12 replies |
robert222776
CSS with PowerCMS2
I am a version 1.02 developer, and have always felt that the application of (class) styles (called out on the external style sheet controlling the site pages) by the client/user was straightforward enough, but it was the addition of the class styles by the developer to the drop down, so they were accessible to the client/user in the internal html editor, was tricky at best. Judging from the number of threads on CSS, others found this to be true too.
From the demo for PowerCMS2 I see that the client/user will still have the styles, format, etc., drop downs available to them, and referring to your latest FAQs, your Q regarding CSS "Can a user select various styles......." your answer was:
"Out of the box, PowerCMS only gives users the ability to define text as Heading 1, Heading 2, etc. However, PowerCMS does NOT currently allow users to select various CSS styles. Instead, when a user adds content within PowerCMS the content will automatically inherit any existing CSS styles of the page being edited."
Do you really mean "NOT". If users are NOT allowed to select various CSS styles, then isn't this a step backward in capability from version 1.02?
In your demo, if you look at the source view for the Del Mar page, you will find various classes (top, stat, label, bottom, etc.) used throughout the page source: For example:
<p class="stat">25,000</p>
How is this class being added if not from the drop down for "style" (which is not there, by the way, as a choice)? Granted it could have been originally introduced by the developer, and only the number edited by the client/user, but what if the client/user was creating new content that included this line, and wanted to use the class "stat" to complete the style? How does he implement it if he knows nothing about html and is intimidated by the source view?
Finally, and once and for all, if the style drop down IS available for classes, what is the most straight forward way to make the external style sheet classes accessible via the editor (style) drop down?
Thanks,
Robert
craigs386868
I Agree
Couldn't agree more! This feature should be standard no doubt about that.
I'm currently fishing around here trying to find a post to give a step by step on how to add styles to the styles drop down so if you find one that is strait forward please let me know.
Ahh sorry just found out you need another Web Assist extension to add functionality to the style drop down.... "HTML Editor" if you have that then you can make custom changes and link that menu to a css file... or so someone has mentioned in a post. I haven't tried this yet. Will let you know if I have any joy.
Neil Beadle
The CSS styles feature in PowerCMS 2 is the same as it was in PowerCMS 1. We are trying to work out a solution where you could reference your website's style sheet to have all the styles available in the HTML Editor, as well as applied to the content when displayed in PowerCMS.
Unfortunately, the fckeditor which our HTML Editor relies on doesn't accommodate for CSS style sheets in a way that would make this implementation very easy - but we are considering ways to handle this in the future.
neilo
Originally Said By: Neil Beadle
So you can add your own styles through HTML Editor, then? Or have you adjusted the HTMLEditor code in CMS2 to prevent this? Sorry Neil, but just a bit confused about the double message here!
neilo
Hi Craig,
Yes - if you have HTMLEditor, it should be straight forward, but there is a knack to it.
If you have HTMLEditor and want a rundown on what procedure works for me, I'd be happy to post it.
Although it seems from previous posts in this thread that there is now some doubt about this facility still being available in CMS2.
Awaitin confirmation!
neilo
Oi tommysebazco,
Behave yerself. You've posted same message on several different threads under several different product types.
Either ask a proper question or stop posting.
robert222776
Thanks for the replies.
Neil, please advise on when (future?) there might be a built in solution to the "class" issue. Speaking for myself only, I see this lack of functionality (i.e ability to show classes in the style drop down) as a major deficiency in this application, be it PCMS1 or PCMS2.
Neilo, I know there have been many posts about this issue, but I would appreciate a posting of your work-around again so we have interim solution. I presently have PCMS1, but would consider PCMS2 if your work-around requires it. I also have the stand-alone HTML editor.
Thanks,
Robert
neilo
Hi Robert,
I will post back with a step by step solution that seems to work for people who have tried it (at least in CMS1).
It may not be for a while (few hours - 1 day) but I will post it.
robert222776
That's great neilo....thanks!
Robert
Neil Beadle
Neilo,
Yes, you should be able to reenter the HTML Editor instances in PowerCMS in HTML Editor to include your own style sheet. This will allow you to include the various classes you want from the Styles menu in the toolbar.
However, this will not change how the content appears when viewed in PowerCMS.
Robert,
This is currently just a feature request and something we are looking at handling in a future version of PowerCMS. We have no timeline on when that might be. Sorry.
-Neil
