templates
Thread begun 4/12/2010 2:48 am by i.edwards384429 | Last modified 7/26/2010 12:56 am by i.edwards384429 | 2024 views | 3 replies |
i.edwards384429
templates
Hi
don't know if this is down to my DW installation but I found that when adding PS3 to an existing site the templates did not work.
Using the little grey cells I remembered that templates should be in the root.
I opened the supplied templates and then selected file--- save as template and saved etc.
The template was then moved into my root template directory and everyhting worked OK
HTH
Ian
for the templates to work properly, the Power Store files need to be at the root o your Dreamweaver Site.
ricardo396864
to i.edwards384429
Can you post a link to your site i want to see what it looks like with a customized template as that is what i am trying to do
i.edwards384429
links
Hi
here's a couple of simple ones
www.system2security.co.uk and www.cookersrus.co.uk
I'm working on another which completely changes the whole look but thats work in progress.
cheers
Ian
