Order History/ No UserID in Store Summary Database
Thread begun 4/12/2010 1:34 am by Nature Photographer | Last modified 8/25/2010 10:20 am by Jason Byrnes | 5196 views | 10 replies |
Nature Photographer
I'm using eCart5 with PayPal Standard, I set up the store with all files etc and it works great and have now moved on to setting up the order history BUT when I go into the eCart Store Summary in Database server behavior there is no listing to bind OrderUserID. There is two entries relating to payPal which wasn't there in ecart 4.
The mySQL does have a column for orderUserID and everything else is there which is mentioned in the guide except this one binding entry of OrderUserID
I've attached a screenshot of my bindings available.
Thanks for your assistance.
to create an order history, you must be requiring the users to login before the can checkout.
see the "Applying Register/Login to your checkout" tutorial on the eCart support page:
ecart/
Nature Photographer
Hi, yes I have done all that, as in login required, if you had checked the attached screen shot you would have seen the various bindings.
As I said originally. everything works fine up to the history pages I was trying to save you guys some time by keeping my question simple.
So Ok!
1. I have read the "Getting started with eCart guide"
a. I have checked the php mySQL Database that all required table columns are available
b. I have completed eCart Object
c. I have added eCart buttons to pages as required
d. I have applied the Display Manager wizard
e. I have applied Checkout wizard
Everything works, I can add to cart, I can Check out, details are added to database
2. I read and applied "applying Registrer/Login to your checkout"
Everything works fine, people are redirected to login page when not already login etc etc
3. Have read and applied "Automatically populate form fields on your checkout page"
Everything works fine, details from data base are filling form during checkout
4. Have read and applied "How to create an order history" but when I go into the eCart Store Summary in Database server behavior there is no listing to bind OrderUserID in the session list
the session variable name to use may be different. to determine what the correct session variable name is, open the security assist login page and double click the security assist authenticate user server behavior, on the third page the session variables will be listed, make note of the session variable name for the ID column.
If this session variable is not listed on the bindings panel, you can add it manually. on the bindings panel, click the plus button and select Session Variable, then type the name for the user ID session variable.
NOTE: PHP is case sensitive, when adding the binding, make sure to use the correct case.
Nature Photographer
Thanks Jason,
jbarron397794Beta Tester
Cannot store in UserID column!
Great instruction in this thread, however I set my store up before we purchased Security Assist so all of my pages are using the standard Dreamweaver authentication sign in with the exception of my log in page which is using WebAssist cookie toolkit. (...I recently changed my login page so that I could have the remember me feature, in which it does.) So now every time I put in what I believe the session name to be that was set by the Dreamweaver extension I get an error that says "You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near '@myemail.com)' at line 1"
I have a column in my orders database called "OrderUserID" but I just can't get it to store. Please advise so I can finally get beyond the 2nd paragraph of your "Build History Page" PDF.
Thanks~
this error suggests that the session parameter is being treated as a number.
in the recordset where you are using the email address session variable in the parameter, set the type to text instead of number.
Thanks Jason. That worked because my userID session is actually set as the user's email address. (Again, I purchased the DataAssist and SecurityAssist AFTER I had already purchased ecart.) It is now storing the username (email) of the person who logged in into the UserID column. HOWEVER, after following the step by step directions and completing all pages correctly, it is now displaying ALL orders for everyone, not just for that specific user. Any suggestions on what might be happening? I have a attached a screenshot of my recordset and I have pasted the code for the session here. Please advise why when I am following the tutorial, it still will not work? Thanks for your help!
// WA eCart Store Cart Summary in Db
if (($_SERVER["REQUEST_METHOD"] == "POST") && (isset($_SERVER["HTTP_REFERER"]) && strpos(urldecode($_SERVER["HTTP_REFERER"]), urldecode($_SERVER["SERVER_NAME"].$_SERVER["PHP_SELF"])) > 0) && isset($_POST)) // Trigger
$WA_connection = $rsmyconnect;
$WA_table = "orders";
$WA_redirectURL = "";
$WA_indexField = "OrderId";
$WA_fieldNamesStr = "OrderReferenceId|OrderVisitorID|OrderDeptCode|OrderShipping|OrderTax|OrderTotal|OrderCompany|OrderShipAddress1|OrderShipAddress2|OrderShipCity|OrderShipStateId|OrderShipZip|OrderShipCountryId|OrderUserID";
$WA_fieldValuesStr = "".session_id() ."" . "|" . "".$_SESSION['eCartCheckoutForm_email'] ."" . "|" . "".$ecart1->GetTax() ."" . "|" . "".$ecart1->GetShipping() ."" . "|" . "".$ecart1->GrandTotal() ."" . "|" . "".((isset($_POST["deptcode"]))?$_POST["deptcode"]:"") ."" . "|" . "".((isset($_POST["shipping_company"]))?$_POST["shipping_company"]:"") ."" . "|" . "".((isset($_POST["shipping_street1"]))?$_POST["shipping_street1"]:"") ."" . "|" . "".((isset($_POST["shipping_street2"]))?$_POST["shipping_street2"]:"") ."" . "|" . "".((isset($_POST["shipping_city"]))?$_POST["shipping_city"]:"") ."" . "|" . "".((isset($_POST["shipping_state_province"]))?$_POST["shipping_state_province"]:"") ."" . "|" . "".((isset($_POST["shipping_postcode"]))?$_POST["shipping_postcode"]:"") ."" . "|" . "".((isset($_POST["shipping_country"]))?$_POST["shipping_country"]:"") ."" . "|" . "".$_SESSION['MM_Username'] ."";
$WA_columnTypesStr = "',none,''|',none,''|',none,''|',none,''|',none,''|',none,''|',none,''|',none,''|',none,''|',none,''|',none,''|',none,''|',none,''|',none,''";
$WA_sessionName = "ecart1_OrderID";
$WA_Sql = "";
$NeedInsert = false;
$indexFieldIndex = -1;
$WA_connectionDB = $database_rsmyconnect;
$updateFieldValue = "";
if ($WA_redirectURL != "" && isset($_SERVER["QUERY_STRING"]) && $_SERVER["QUERY_STRING"] !== "" && sizeof($_POST) > 0) {
$WA_redirectURL .= ((strpos('?', $WA_redirectURL) === false)?"?":"&").$_SERVER["QUERY_STRING"];
for ($i = 0; $i < sizeof($WA_fieldNames); $i++)
if ($WA_indexField == $WA_fieldNames[$i])
$indexFieldIndex = $i;
break;
$deleteFieldValue = "";
$updateColType = "none,none,NULL";
if ($indexFieldIndex >= 0) $updateFieldValue = $WA_fieldValues[$indexFieldIndex];
if ($updateFieldValue == "" && isset($_SESSION[$WA_sessionName])) $updateFieldValue = $_SESSION[$WA_sessionName];
if ($indexFieldIndex >= 0) $updateColType = $WA_columns[$indexFieldIndex];
if ($updateFieldValue != "") {
$updateParamsObj = WA_generateInsertParams($WA_fieldNames, $WA_columns, $WA_fieldValues, $indexFieldIndex);
$valueForWhere = WA_generateInsertParams(array($WA_indexField), array($updateColType), array($updateFieldValue), -1);
$WA_Sql = "update " . $WA_table . " SET " . $updateParamsObj->WA_setValues . " where " . $WA_indexField . " = " . $valueForWhere->WA_dbValues;
$WA_editCmd = mysql_query($WA_Sql, $WA_connection) or die(mysql_error());
$_SESSION[$WA_sessionName] = $updateFieldValue;
$result = mysql_query("SELECT * FROM " . $WA_table . " where " . $WA_indexField . " = " . $valueForWhere->WA_dbValues, $WA_connection);
$num_rows = mysql_num_rows($result);
$NeedInsert = (mysql_num_rows($result) === 0);
if ($updateFieldValue === "" || $NeedInsert) {
$insertParamsObj = WA_generateInsertParams($WA_fieldNames, $WA_columns, $WA_fieldValues, -1);
$WA_Sql = "insert into " . $WA_table . " (" . $insertParamsObj->WA_tableValues . ") values (" . $insertParamsObj->WA_dbValues . ")";
$_SESSION[$WA_sessionName] = mysql_insert_id();
if ($WA_redirectURL != "") {
header("Location: ".$WA_redirectURL); exit;
judging by the screen shots of your recordsets, it is not possible for it to display all records unless the code on the server does not include the update recordsets. make sure that the pages are being uploaded properly.
Hi Jason, thanks... The pages have definitely been uploaded to the server! I even ftp'd them again just to be on the safe side before I retested. It is still displaying all records no matter whom I sign in as. Please help!
Also, when I click on the Order ID from the customer_history page it comes up as 'No results for your search'! As if it is not linked properly. Again, please help!
