eCart confirm.php error
Thread began 4/11/2010 12:02 pm by nicolelagden329266 | Last modified 4/18/2010 6:14 am by nicolelagden329266 | 1046 views | 2 replies |
nicolelagden329266
Hi
I have managed to set up a cart and the checkout pages and it is fine until I click on the submit button within confirm.php, then I just get a blank screen.
I was getting this error message:
Warning: set_time_limit(): Cannot set time limit in safe mode in /var/www/vhosts/juppfinejewellery.co.uk/httpdocs/confirm.php on line 185
Notice: Use of undefined constant undefined - assumed 'undefined' in /var/www/vhosts/juppfinejewellery.co.uk/httpdocs/confirm.php on line 187
Notice: Use of undefined constant undefined - assumed 'undefined' in /var/www/vhosts/juppfinejewellery.co.uk/httpdocs/confirm.php on line 188
Notice: Use of undefined constant undefined - assumed 'undefined' in /var/www/vhosts/juppfinejewellery.co.uk/httpdocs/confirm.php on line 189
Warning: Division by zero in /var/www/vhosts/juppfinejewellery.co.uk/httpdocs/confirm.php on line 203
Warning: Division by zero in /var/www/vhosts/juppfinejewellery.co.uk/httpdocs/confirm.php on line 223
Fatal error: Call to undefined function: session_commit() in /var/www/vhosts/juppfinejewellery.co.uk/httpdocs/confirm.php on line 232
I found a thread in your forum that suggested I change :
$BurstSize = undefined;
$BurstTime = undefined;
$WaitTime = undefined;
to
$BurstSize = 200;
$BurstTime = 1;
$WaitTime = 1;
which sorted out some of the error messages, now I just get:
Sorry I am very new to this, please can you help as I can't seem to get any further?
Many Thanks
when php is configured to run in safe mode, certain features will be turned off:
features.safe-mode.php
Universal Email is not compatible with PHP servers configured to run in safe mode, safe mode will need to be turned off.
Try changing line 232 from
session_commit();
session_write_close();
nicolelagden329266
checkout_failure
Thanks, that seemed to do the trick, although I had to change session_commit(); to:
session_write_close(); in a couple more places too.
Now, unfortunately I have a new problem, I used the eCart wizard for SagePay VSP Server and it always goes to the checkout_failure.php page, I can't seem to get it to work. I noticed one other thread on your forum (SagePay / Protx Problems) and they suggested deleting the entries for Billing State and Delivery State as they seemed to cause an error when they were changed to UK counties. I have tried this but it didn't work. I also tried to follow the article "Debugging eCart Transaction Failure issues" but nothing appeared to happen.
Is there anything else I could do?
Many Thanks
