Problem with Detail/Update pages for some records
Thread begun 4/10/2010 11:06 am by daniel402139 | Last modified 4/15/2010 2:47 pm by Eric Mittman | 3064 views | 3 replies |
daniel402139
First time post on this site. Hope I can get my problem fixed.
I'm using the DataAssist extension and having some problems. I use the DataAssist Wizard to generate these pages:
Search, Detail, Update, Results
Everything seems to work perfectly with all the functionality working, except for the following two problems:
1. When I try to view a detail page, the link does not work. The field that I am trying to link on is a 15-digit number. By default, the wizard declares the variables below as "double" data type, and the the link does not work. When I change the data type from "double" to "decimal" as shown below, the linking works:
$query_WADAtblproperties = sprintf("SELECT * FROM tblproperties WHERE Roll = %s OR ( -1= %s AND Roll= %s)", GetSQLValueString($ParamRoll_WADAtblproperties, "decimal"),GetSQLValueString($ParamRoll2_WADAtblproperties, "decimal"),GetSQLValueString($ParamSessionRoll_WADAtblproperties, "decimal"));
Does this fix that I somehow discovered make sense? Should I need to be playing around with the data types after the wizard has created the pages? I don't know if making this change is somehow causing my second problem.
2. The second problem is that the links to the Detail and Update pages are working only intermittently at best. For example,
- some records link correctly to the correct Detail and Update pages;
- some records result in 'No Record Found', but should be finding records; and
- some records link to the wrong Detail and Update pages. Although the correct record number is shown in the URL, the resulting WADADetailsContainer displays data from a different record. i.e. record 1 shown in URL, but record 2 details displayed in container.
Those are my two problems. If someone can help me figure these out I would be eternally grateful. Kind regards,
Dano
The second problem that you are having may very well be related to the first problem and the change that you have made.
When I do a test on this I can see that my query sets the data type to match the key column that I select in the wizard. In my test my key column was of type int and this is the type of data used in the query on the details page. What is the column that you choose as the key column in the wizard for this table and what is it's datatype in your db? I wonder if updating it to work with a varchar would resolve this problem.
Please post back with this info so we can look into this issue further.
daniel402139
Thanks for the comment Eric. I changed my data type from Double to Decimal and that did not work. Then I followed your suggestion and changed the data type to Varchar(15) and this did the trick. Everything works perfectly when the proper data type is used. I appreciate you steering me in the right direction.
I'm very glad to hear that, let us know if you have any further questions or run into any issues.
