display session variable
Thread began 4/09/2010 12:14 pm by pogro711404698 | Last modified 4/13/2010 5:10 pm by Eric Mittman | 1681 views | 4 replies |
pogro711404698
hi,
i need help on how to do this.
on my log in page, i did (server behavior > SecurityAssist authenticate user> and created a session variable first_name.
here is the code for the log in page:
<?php require_once('Connections/boulevardstyle.php'); ?>
<?php require_once('Connections/boulevardstyle.php');?>
<?php require_once( "WA_SecurityAssist/Helper_PHP.php" ); ?>
if(isset($_POST["button_x"])){
$WA_Auth_Parameter = array(
"connection" => $boulevardstyle,
"database" => $database_boulevardstyle,
"tableName" => "users",
"columns" => explode($WA_Auth_Separator,"emailaddress".$WA_Auth_Separator."password"),
"columnValues" => explode($WA_Auth_Separator,"".$row_users[''] ."".$WA_Auth_Separator."".((isset($_POST["password"]))?$_POST["password"]:"") .""),
"columnTypes" => explode($WA_Auth_Separator,"text".$WA_Auth_Separator."text"),
"sessionColumns" => explode($WA_Auth_Separator,"1st_name"),
"sessionNames" => explode($WA_Auth_Separator,"first_name"),
"successRedirect" => "index1.php",
"failRedirect" => "re_userLogIn.php",
"gotoPreviousURL" => TRUE,
"keepQueryString" => FALSE
WA_AuthenticateUser($WA_Auth_Parameter);
switch ($theType) {
case "text":
break;
case "long":
case "int":
break;
case "double":
$theValue = ($theValue != "") ? "'" . doubleval($theValue) . "'" : "NULL";
break;
case "date":
break;
case "defined":
break;
return $theValue;
mysql_select_db($database_boulevardstyle, $boulevardstyle);
$query_users = "SELECT * FROM users";
$users = mysql_query($query_users, $boulevardstyle) or die(mysql_error());
$row_users = mysql_fetch_assoc($users);
$totalRows_users = mysql_num_rows($users);
// *** Validate request to login to this site.
if (!isset($_SESSION)) {
session_start();
$loginFormAction = $_SERVER['PHP_SELF'];
if (isset($_GET['accesscheck'])) {
$_SESSION['PrevUrl'] = $_GET['accesscheck'];
if (isset($_POST['emailaddress'])) {
$loginUsername=$_POST['emailaddress'];
$password=$_POST['password'];
$MM_fldUserAuthorization = "";
$MM_redirectLoginSuccess = "index1.php";
$MM_redirectLoginFailed = "re_userLogin.php";
$MM_redirecttoReferrer = false;
$LoginRS__query=sprintf("SELECT emailaddress, password FROM users WHERE emailaddress=%s AND password=%s",
GetSQLValueString($loginUsername, "text"), GetSQLValueString($password, "text"));
$LoginRS = mysql_query($LoginRS__query, $boulevardstyle) or die(mysql_error());
$loginFoundUser = mysql_num_rows($LoginRS);
if ($loginFoundUser) {
$loginStrGroup = "";
//declare two session variables and assign them
$_SESSION['MM_Username'] = $loginUsername;
$_SESSION['MM_UserGroup'] = $loginStrGroup;
if (isset($_SESSION['PrevUrl']) && false) {
$MM_redirectLoginSuccess = $_SESSION['PrevUrl'];
header("Location: " . $MM_redirectLoginSuccess );
else {
header("Location: ". $MM_redirectLoginFailed );
and this is the page code where i want the 1st name of the user to be displayed:
pogro711404698
switch ($theType) {
case "text":
break;
case "long":
case "int":
break;
case "double":
break;
case "date":
break;
case "defined":
break;
return $theValue;
session_start();
else {
<html xmlns="http://www.w3.org/1999/xhtml"><!-- InstanceBegin template="/Templates/dynamics.dwt" codeOutsideHTMLIsLocked="false" -->
<head>
<!-- InstanceBeginEditable name="doctitle" -->
<title>User Log In | boulevardstyle.com</title>
<!-- InstanceEndEditable -->
<style type="text/css">
body,td,th {
font-family: Arial, Helvetica, sans-serif;
color: #333333;
</style>
<script src="SpryAssets/SpryMenuBar.js" type="text/javascript"></script>
<link href="SpryAssets/SpryMenuBarHorizontal.css" rel="stylesheet" type="text/css" />
<link href="boulevard_style.css" rel="stylesheet" type="text/css" />
<link href="SpryAssets/SpryMenuBarVertical.css" rel="stylesheet" type="text/css" />
.style2 {color: #FF0000}
</style>
.style3 {color: #EE1C25}
.style4 {font-size: 12px}
</style>
<!-- InstanceBeginEditable name="head" -->
<script src="SpryAssets/SpryValidationTextField.js" type="text/javascript"></script>
<link href="SpryAssets/SpryValidationTextField.css" rel="stylesheet" type="text/css" />
.style7 {color: #134D92}
</style>
</head>
<body>
<div id="top">
<div id="logo"><img src="images/logo.jpg" width="147" height="152" /></div>
<!-- InstanceBeginEditable name="EditRegion5" -->
<div id="dynamicInfo"><?php echo $_SESSION['first_name']; ?>| <a href="#">Your Account</a> |<a href="#"><img src="images/shopping_cart-32.png" width="34" height="30" border="0" align="absbottom" /></a> <a href="#">Cart</a> </div>
<div id="search">
<form id="form1" name="form1" method="post" action="">
<label>
<input name="search" type="text" id="search2" />
</label>
<label>
<input name="button" type="image" id="button" value="Submit" src="images/arrow_right.gif" align="bottom" />
</label>
</form>
</div>
<div id="navigation">
<ul id="MenuBar1" class="MenuBarHorizontal">
<li><a href="index.html">Boulevard Style</a> </li>
<li><a href="product_gallery.html">Product Gallery</a></li>
<li><a href="comunity_fund.html">Community Fund Raising</a> </li>
<li><a href="about_us.html">About Us</a></li>
<li><a href="contact_us.html">Contact Us</a></li>
</ul>
</div>
</div>
<div id="main">
<div id="bodypage_contact"><!-- InstanceBeginEditable name="left_nav" -->
<div id="left">
<p><strong>About Boulevard<br />
<br />
<img src="images/mail_32.gif" width="32" height="32" align="absmiddle" /> E-mail:</strong><a href="mailto:info@boulevardstyle.com">info@boulevardstyle.com</a></p>
<p>ORDER BOULEVARD FASHIONS<br />
<span class="style3">Online ordering coming soon!</span></p>
<p><a href="comunity_fund.html">Community Fund Raising</a><br />
<a href="sales_rep.html">Become a Sales Rep</a><br />
<a href="fashion_icon.html">Become a Boulevard Fashion Icon</a><br />
<a href="boulevard_community.html">Join the Boulevard Community</a><span class="style4"><br />
</span></p>
</div>
<div id="right"><!-- InstanceBeginEditable name="rightConts" -->
<div id="c_left">
<p class="style2"><span class="ShoeName style7">Log In</span><br />
</p>
<form ACTION="<?php echo $loginFormAction; ?>" id="form2" name="form2" method="POST">
<table width="331">
i dragged the session variable first_name to tha place where i want it to be displayed but i did not get any result...
any help would be highly appreciated
thanks
Is the problem that you are not getting logged in, or that you are logged in and the first_name session var is not set?
I can see a couple of potential problems in your authenticate user server behavior. The first issue that I see is that you are referencing the column values like this:
You will need to reference the username or email field from your login form instead of the empty recodset value that is currently being used.
The other thing that I noticed is that the first name column in your table is set as 1st_name, in my experience it is not a good idea to have a number starting off a column name. I'm not sure if this has any relation to the problem you are experiencing but it is something that I noticed.
pogro711404698
i was able to log in, after logging in i am directed to the page i set. my problem is, i don't see that user first name where i dragged that session variable.
thanks
Please post back with the login page and the page you are trying to view the value on. Please include these files in a zip archive attached to the post. I will take a look and if I need any additional info or files I will let you know.
