Settings get Erased?
Thread begun 4/08/2010 2:30 pm by elevy388997 | Last modified 4/21/2010 12:26 pm by Eric Mittman | 8717 views | 13 replies |
elevy388997Beta Tester
Hello,
I am using the Sculptor to make my own layout and every time it deletes things. When I am adjusting the TYPE information sometimes the things I put in just disaapear, or changes i make aren't applied. So I close out and open it back up and most of the changes are there, but the TYPE stuff I have to put in again. Hopefully this makes sense...also the text boxes vanish every time, forcing me to save.
It literally is 2 steps forward, 1 back. I have been trying to get the TYPE settings worked out for a good hour now... also the contentWrapper isn't working for me. I have a 10px tall image (width is same as document) set as the image for the contentwrapper with a repeat of x. When I enter through the page to add lines, it puts spaces with a transparent background and just shoves everything else down.
EDIT: Posted more pictures of problems
webassist/
I have opened a ticket for you on this issue. To check on the status of your ticket or update it login and visit your support history.
Thank You, Ill keep my eye on the responses.
EDIT: I don't know if you still want me posting questions here, but:
"So I uploaded one of the pages so you can see a Live version of the site. This is more for the #contentwrapper problem.
www.animation.levy4u.com/ "
Thanks for posting with the link. I'm not fully sure that I understand the steps that you took to get this result. Could you post back and include some more info about those steps and also include the image in question that you are applying for the background that is having this issue. I will take a look at this more to see what I can find.
I can do one better, I am uploading a video to youtube displaying the problems. Make sure your increase quality and full screen if necessary.
CSS Sculptor - watch?v=dxgzxxeYtOI
ContentWrapper - watch?v=6J6ROf5rvF4
In regards to what you are experiencing with the content wrapper this looks like the regular behavior when using a rounded corners layout. The problem with the rounded corners layouts are that they work on images attached to the top and bottom of the areas. When you add to an area and increase it's size you will make a gap between the images, making it look like the background for that content area is missing.
To avoid this you should be extending the vertical size of the content area with the css fist to accommodate the text or larger content that you will include on the page.
Ok, I will give that a try. If it makes a difference, I selected to make a custom layout and applied images that I created, to the header, content, footer.
EDIT: It worked...how funny it is to do something so easy and it fixes hours of frustration. Thank You for fixing that problem.
I'm glad to hear that. Let us know if you have any other questions.
Captcha Image only display "Security Image"
Well im not thinking...I forgot to upload the WA_ValidationToolkit folder to my server...it works now
I do have a question though. With UE4 I have an attachment field to upload file, and it gets to the server fine, but I want it to be emailed with the form as well. And with the dynamic labels (using the block template) it has the form name "contact_me_" then the field label "Name", "Company" etc. It makes the email very messy. Any ideas?
You can edit the message directly and just make your own labels for the info, anywhere that you want to see information from the form you can use the bindings to drag and drop the form value onto the message page where you would like to see it.
