Recordset cannot be updated
Thread begun 4/08/2010 8:18 am by bjgarner241692 | Last modified 4/14/2010 12:20 pm by Jimmy Wu | 4266 views | 5 replies |
bjgarner241692
Why is it that on PHP pages I cannot use the Behaviour Tools to change a recordset. Whenever I edit a recordset it does not edit the existing code, instead it inserts new code after it. I've seen this in ASP pages as well I think. It has been happening for quite a while, on my old machine and again on my new machine.
if (PHP_VERSION < 6) {
switch ($theType) {
case "text":
break;
case "long":
case "int":
break;
case "double":
break;
case "date":
break;
case "defined":
break;
return $theValue;
$param_product = "-1";
if (isset($GET_URL['ID'])) {
$param_product = (get_magic_quotes_gpc()) ? $GET_URL['ID'] : addslashes($GET_URL['ID']);
mysql_select_db($database_constring, $constring);
$query_product = sprintf("SELECT * FROM life_prods INNER JOIN prod_pricing ON life_prods.Name = prod_pricing.ProdName WHERE %s = life_prods.ID ORDER BY prod_pricing.Price", GetSQLValueString($param_product, "int"));
$product = mysql_query($query_product, $constring) or die(mysql_error());
$row_product = mysql_fetch_assoc($product);
$totalRows_product = mysql_num_rows($product);$param_product = "-1";
if (isset($_GET["ID"])) {
$param_product = (get_magic_quotes_gpc()) ? $_GET["ID"] : addslashes($_GET["ID"]);
Jimmy Wu
Did you make any modifications to the recordset by hand before trying to edit using the server behaviors panel?
Recordsets are Dreamweaver functionality, so if you are able to duplicate this functionality regularly, it might be better to contact Adobe Support.
bjgarner241692
No, I did not edit it by hand.
I can tell you it only happens on pages with a WA extension on it and it has been an ongoing issue.
Jimmy Wu
Could you send me the page so I can test it and see if I get the same issue?
neilo
Hi Jimmy,
I am currently getting similar results when I edit a recordset. Even if I just open the recordset from the server behaviors panel and close it without making any changes, the recordset code is duplacated. I have got used to having to go to code view and removing the extra code, but sometimes I forget - and am only reminded of it when I upload the page and get the error message,
"Fatal error: Cannot redeclare getsqlvaluestring() (previously declared in /home/hackers/public_html/ue4/index.php:25) in /home/hackers/public_html/ue4/index.php on line 85"
This has only been happening fairly recently, so I am not sure what the catalyst is. All that I have added is UE4, but - as you say - recordsets are a DW functionality, but I can't see that opening a dialogue with Adobe would help too much as I have not updated DW itself in any way. I'm guessing it's (my) user error I suppose, but I just can't work it out why.
Have made a 2 page DataAssist page-set (results, Delete) to demonstrate.
Jimmy Wu
This is very interesting behavior, since I cannot reproduce it. It could be the structure of the database table that is causing the issue. Which columns do you have and what types are they specified as in your db?
