Problem with update page
Thread begun 4/08/2010 7:39 am by Gabriel Tiviroli | Last modified 4/08/2010 4:45 pm by Jimmy Wu | 1015 views | 1 replies |
Gabriel Tiviroli
Hello friends, I have a problem with file uploads using the new Universal Mail 4. The problem I have it especially when I want to update. I have used Data Assist In order to make the back end of the site and everything works fine but in general, for example, when inserting no problem, if I have the update page because although all procedures carried out properly - even following the tutorial offered by the way, when I edit a record in the fields that are to upload images I get no default image, then when I do the update the image I had previously that had been inserted using the insert-page disappears or I have to put it back again. I can do to solve this problem? I hope you understand what is asked.
Jimmy Wu
I'm not sure if I completely understand what you're asking, but I can give you some pointers on setting up an upload on an update. If you're setting up the upload and want the update to keep the original if the file field is left blank, you will have to create a recordset that gets the row with the previous file name. Then open up the upload server behavior and click on the lightning bolt next to the default file field. Then select the recordset value for the filename. To ensure that the value is saved, try clicking inside the default file field and hitting tab. Then apply the upload.
