Delete Behaviour
I'm having trouble deleting a record. The database structure is unusual in as much as I have the ID and the field showing the same information.
so:
serviceID servicename
Morning Morning
Evening Evening
South Green South Green
Now this works fine as long as there is not a space in the serviceID column. So it will delete Evening and Morning but NOT South Green.
This is the PHP code
// WA Application Builder Delete
if (isset($_POST["Delete_x"])) // Trigger
$WA_connection = $localhost;
$WA_table = "bbc_service";
$WA_redirectURL = "bbc_service_Results.php";
$WA_keepQueryString = false;
$WA_fieldNamesStr = "serviceID";
$WA_columnTypesStr = "',none,''";
$WA_fieldValuesStr = "".((isset($_POST["WADADeleteRecordID"]))?$_POST["WADADeleteRecordID"]:"") ."";
$WA_comparisonStr = "=";
$WA_comparisions = explode("|", $WA_comparisonStr);
$WA_connectionDB = $database_localhost;
$deleteParamsObj = WA_AB_generateWhereClause($WA_fieldNames, $WA_columns, $WA_fieldValues, $WA_comparisions);
$WA_Sql = "DELETE FROM `" . $WA_table . "` WHERE " . $deleteParamsObj->sqlWhereClause;
if ($WA_redirectURL != "") {
Is there anything I can add / alter to that code that will allow the deletion of a record that has a space in the ID?
I know that this was probably bad design when I did this (about a year ago now) but it seemed a good idea at the time. If I was to change the ID to a numeric value now it would involve changing an awful lot of pages else where in the site that uses the data. So If there is a simple solution I'd be grateful to know it. Like adding an underscore if there is a space for example. The code is beyond my level of expertise I'm afraid.
Many thanks.
