Asked for NEW API key???
Thread begun 4/08/2010 3:58 am by esms | Last modified 4/08/2010 10:19 am by Jimmy Wu | 1434 views | 2 replies |
esmsBeta Tester
Hello,
For around a year one of the sites I created used Google Maps without a problem. Today, the client contacted me to tell me he now sees the attached error message stating a NEW key is required.
However, when I generate a key again, it gives me the same API number. And, of course, I still see the same erro message.
Any ideas how to create a new / different key?
Cheers
esmsBeta Tester
Sorted it. Bizarre. I discovered how to generate a new API for the site. However, when I fill the new number into Pro Maps For Google, it gives me every indication it has accepted the new number but when I look at the code, it hasn't!! So, I just copied and pasted the new API number into the code view in DWCS4 and it worked.
Latest version of PMFG, by the way.
Any ideas why it might not write the new API into the relevant line of code?
It's working now, so only look into this in a idle moment.
Jimmy Wu
It could just be the value isn't stored. Try hitting tab/enter after entering the API key and see if it writes the key out.
