Customizing the Data Assist detail.php page
Thread begun 4/06/2010 2:45 pm by donald.dickson338135 | Last modified 4/07/2010 3:06 am by donald.dickson338135 | 1700 views | 2 replies |
Hello I have used Data Assist to revise the pages originally supplied as part of the Security Assist solution web and database. The database is the ubiquitous Blue Sky Music and all the product images and thumbnails are in the correct folders
I have followed the instructions in the Data Assist gsg and recreated the pages though instead of naming the pages items_*.php etc I named them prod_*2.php
In my case the items_detail.php page is therefore called prod_detail2.php
Search results works and I click the view (mag icon) to open the prod_details2.php
The issue is I cannot get the images to display on the prod_detail2.php page.
In the gsg is this info about binding the image.
Step 11. With the dynamic image selected, prepend the relative path to the Src value in the Property inspector. For our example, you would add images/detail/.
For my page prod_detail2.php in properties src = <?php echo $row_WADAitems['ItemImage']; ?>
The page code is <div id="WADAPageHeaderImageArea"> <img id="WADAPageHeaderImage" src="<?php echo $row_WADAitems['ItemImage']; ?>" alt="" />
I tried changing the Properties src value to images/detail/<?php echo $row_WADAitems['ItemImage']; ?> but that did not result in the image being displayed.
Viewing the content of the Tag Editor I can see the following
where exactly do I insert images/detail/ as instructed please?
Don
Russell CollinsBeta Tester
modify path setting
you probably need to put ../ at the start as in...
../images/detail/<?php echo $row_WADAitems['ItemImage']; ?>
Regards
Russ
Hello Russ - you are absolutely right and I thank you for your help.
Unfortunately the new "product" images did not appear on the page and that threw me for quite some while until I discovered that the images supplied with the solution support files now did appear. This clearly pointed to missing images though I was sure they were in the images/detail/ folder because I could see them. Renaming some images did not appear to have any affect so it became clear to me that there must be product images in a folder that I was not seeing. The light bulb went on and I took a look at the testing server in htdocs/images/detail/ where, for reasons I am unable to fathom, the "new" product images were conspicuous by their absence. Manually copying the missing images to the folder on the testing server fixed the problem.
Another example of "don't blame the tools" - in this case the WA application.
Of course I still need to figure out why the images files did not automatically transfer onto the testing server, but that is not a DA issue, its another "me not doing something right" issue.
Thanks again Russ for your "spot on help".
Don
