Error Message
Thread begun 4/06/2010 10:26 am by mrobben375515 | Last modified 4/26/2010 2:49 pm by Jimmy Wu | 5220 views | 12 replies |
mrobben375515
Error Message
I just created a new php doc and got the following error message...
Warning: strpos() [function.strpos]: Empty delimiter in /home/content/o/n/e/onetoonemktg/html/upload_failed.php on line 186
here's the url...upload_failed.php
what causes this?
Jimmy Wu
It looks like you're not using strpos correctly on the page:
str_pos
It could be an issue like this:
3782096.htm
How did you create the page and what modifications did you make?
mrobben375515
I created a new php doc, saved and applied the template, and the only changes were I put an <h1> heading and a <p> paragraph in. That's all I did. It's a brand new page, I don't have any idea what went wrong...
Jimmy Wu
It looks like you've made quite a few changes to the template. If you post the page, I can try taking a look at the file and see if I can tell what's wrong.
mrobben375515
here are the files...thanks
mrobben375515
Any luck finding the error?
Jimmy Wu
The line of code looks fine to me. If you detach the page from the template, then make modifications so line 186 looks like this instead:
if ((strpos($WA_curURL,strtolower($WA_localRoot)) !== false &&
strpos($WA_curURL,strtolower($WA_localRoot)) == 0) &&
(strlen($WA_localRoot) >= strlen($WA_remoteRoot) ||
strpos($WA_curURL,strtolower($WA_localRoot)) === 0)) {
Then the line number the error points at will let us know which strpos call is causing the error.
mrobben375515
sorry, i didn't see that you had replied. here's the error I get now
Warning: strpos() [function.strpos]: Empty delimiter in /home/content/o/n/e/onetoonemktg/html/upload_failed.php on line 178
if ((strpos($WA_curURL,strtolower($WA_localRoot)) !== false && strpos($WA_curURL,strtolower($WA_localRoot)) == 0) && (strlen($WA_localRoot) >= strlen($WA_remoteRoot) || strpos($WA_curURL,strtolower($WA_localRoot)) === 0)) { Register
the page is upload_failed.php
Jimmy Wu
What is the code on line 178?
mrobben375515
the whole php string is...
$WA_localRoot = "".$WAGLOBAL_localRoot."";
$WA_remoteRoot = "".$WAGLOBAL_remoteRoot."";
$WA_curURL = strtolower((isset($_SERVER["PHP_SELF"]))?$_SERVER["PHP_SELF"]:"");
$assumedRoot = $WA_remoteRoot;
$assumedRoot = $WA_localRoot;
