Update Cart Question
Thread begun 4/05/2010 4:48 pm by steven348539 | Last modified 4/07/2010 5:24 pm by Eric Mittman | 2713 views | 4 replies |
steven348539
Yes, back again. I've been playing around trying to add some functionality I've wanted to my cart and things have been going well.
My question is, is it possible to update the price on the cart page after changing the size option? I have it updating the new size in the select list, but not the price.
I know for the details page, I had to have it use a recordset to get the price for that size and assign it to the cart, but I can't see where to do that in the cart page.
You can see the site at www.cis-portraits.com
steven348539
Would it be a matter of going into the cart.php file and in the UpdateCart function, add the recordset using the integer the relates to the size, which is stored in the cart, to grab the right data out of the database and assigning it to $ItemPrice? Or just bypassing assigning it to $ItemPrice and just assign it to $this->Items[$n]->Price?
You could go directly into the code and set it up that way, but if you make any changes to the cart it will undo your additions.
The main problem is that the cart is not designed to work with options that change the price through a selection in the cart itself. The ideal way to do this would be to use calculations to determine the price based on the value of the option. This would work out if you had the value of the option stored along with the option name. If you had it setup this way it would allow you to make edits to the cart without undoing your changes.
steven348539
Thanks for the response. I figured that would be the hazard of modifying the code directly, and which is why I was asking for some guidance :D
I do have the option price stored in the DB already in a separate column. So, if I am currently using this calculation for the price in the cart:
[Price] * [Quantity]
I would want to change it to:
([Price]+$rows_rsPrice['SizePrice']) * [Quantity]
But wouldn't I need to place a recordset somewhere that will use the SizeID that is stored in the cart to grab the price for that size/option? Or is there a way to store it in the cart so it is updated automatically?
You are on the rite track here, but rather than have the recordset reference in the calculation you would want to have another column in your cart to store this value, then when you update the size you will also need to update this other column.
Getting the other column to update to the proper value when you update the selected option would require some js coding. You could have a hidden form element for the other column and a display of the value so that you can see it, then when you update the selected option you could update the value of the hidden form element for the other column. Then when you click on the update button for the cart the columns should all be updated to the new values and the calculations should show you the correct price based on the selected option.
