Simple validation fails
Thread begun 4/04/2010 3:41 am by web_assist_mail157665 | Last modified 4/07/2010 2:50 pm by Jimmy Wu | 1945 views | 3 replies |
ecart checkout
on an include - two folders down
just want to check
address details have been entered
3 fields
add required check - no spaces
redirect fail should return to same page
click checkout (validation on any form press)
no check - order goes on to final place order page, with empty address fields
SB is at top of page (this is the inlcude)
//WA eCart Include
require_once("../../WA_eCart/eCart1_PHP.php");
<?php require_once('../../Connections/con1.php');?>
<?php require_once("../../WA_ValidationToolkit/WAVT_Scripts_PHP.php"); ?>
<?php require_once("../../WA_ValidationToolkit/WAVT_ValidatedForm_PHP.php"); ?><?php
if ($_SERVER["REQUEST_METHOD"] == "POST") {
$WAFV_Redirect = "../../index.php?id_sec=54";
$_SESSION['WAVT_checkout_Errors'] = "";
if ($WAFV_Redirect == "") {
$WAFV_Redirect = $_SERVER["PHP_SELF"];
$WAFV_Errors = "";
$WAFV_Errors .= WAValidateRQ(((isset($_POST["street1"]))?$_POST["street1"]:"") . "",true,1);
$WAFV_Errors .= WAValidateRQ(((isset($_POST["city"]))?$_POST["city"]:"") . "",true,2);
$WAFV_Errors .= WAValidateRQ(((isset($_POST["postcode"]))?$_POST["postcode"]:"") . "",true,3);
if ($WAFV_Errors != "") {
PostResult($WAFV_Redirect,$WAFV_Errors,"checkout");
$eCart1->GetContent();
if (PHP_VERSION < 6) {
switch ($theType) {
case "text":
break;
case "long":
case "int":
break;
case "double":
break;
case "date":
break;
case "defined":
break;
return $theValue;
mysql_select_db($database_con1, $con1);
$query_rs_region = "SELECT * FROM county_cnty LEFT JOIN country_cntry ON county_cnty.fk_id_cntry_cnty = country_cntry.id_cntry ";
$rs_region = mysql_query($query_rs_region, $con1) or die(mysql_error());
$row_rs_region = mysql_fetch_assoc($rs_region);
$totalRows_rs_region = mysql_num_rows($rs_region);
if ($eCart1->IsEmpty()) {
$eCart1->redirStr = "index.php?id_sec=7";
$eCart1->cartAction = "RedirectIfEmpty";
// WA eCart Redirect
if ($eCart1->redirStr != "") {
header("Location: ".$eCart1->redirStr);
?><!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Strict//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-strict.dtd">
<head>
<meta http-equiv="Content-Type" content="text/html; charset=UTF-8" />
<link href="../../WA_eCart/CSS/eC_Checkpoint_Slate_Arial.css" rel="stylesheet" type="text/css" />
</head>
<body>
<div class="articleFree">
<div class="article">
<h4>Booking Stages: </h4>
<p class="eC_small_text">Select Pitch &gt; Enter Pitch Details&gt;Buy Pitch Options<br />
<strong>Confirm Billing Info</strong>&gt;Confirm Costs & Place Booking</p>
<p class="eC_small_text">&nbsp;</p>
<div class="eC_Checkpoint_Slate_Arial">
<h2>Confirm Billing Information</h2>
<div class="eC_CheckoutFormWrapper">
<form name="ecart_checkout_form" action="../../index.php?id_sec=55" method="post">
<div class="eC_PurchaserInfoWrapper">
<div class="eC_CheckoutFormBody">
<div class="eC_FieldsetWrapper">
<table cellpadding="0" border="0" class="eC_HeadingTable"><tr><td><h2>Billing Information</h2></td><td class="eC_bottomLine"><div>&nbsp;</div></td></tr></table>
<table border="0" cellpadding="0" cellspacing="0">
<tr>
<th><label for="firstname" >First name</label></th>
<td>&nbsp;</td>
<td><input name="firstname" type="text" id="firstname" value="<?php echo $_SESSION['kt_firstname_usr']; ?>" size="32" /></td>
</tr>
<tr>
<th><label for="lastname" >Last name</label></th>
<td>&nbsp;</td>
<td><input name="lastname" type="text" id="lastname" value="<?php echo $_SESSION['kt_surname_usr']; ?>" size="32" /></td>
</tr>
<tr>
<th><label for="email" >Email address</label></th>
<td>&nbsp;</td>
<td><input name="email" type="text" id="email" value="<?php echo $_SESSION['kt_email_usr']; ?>" size="32" /></td>
</tr>
<tr>
<th><label for="phone" >Phone number</label></th>
<td>&nbsp;</td>
<td><input name="phone" type="text" id="phone" value="" size="32" /></td>
</tr>
<tr>
<th><label for="fax" >Fax number</label></th>
<td>&nbsp;</td>
<td><input name="fax" type="text" id="fax" value="" size="32" /></td>
</tr>
<tr>
<th><label for="street1" >Address</label></th>
<td>&nbsp;</td>
<td><input name="street1" type="text" id="street1" value="<?php echo $_SESSION['kt_address1_usr']; ?>" size="32" /></td>
</tr>
<tr>
<th><label for="street2" >Address line 2</label></th>
<td>&nbsp;</td>
<td><input name="street2" type="text" id="street2" value="" size="32" /></td>
</tr>
<tr>
<th><label for="city" >City/Town</label></th>
<td>&nbsp;</td>
<td><input name="city" type="text" id="city" value="<?php echo $_SESSION['kt_city_usr']; ?>" size="32" /></td>
</tr>
<tr>
<th><label for="state_province" >Region</label></th>
<td>&nbsp;</td>
<td><select name="state_province" id="state_province" >
<option value="" <?php if (!(strcmp("", $_SESSION['kt_county_usr']))) {echo "selected=\"selected\"";} ?>>Select region</option>
do {
<option value="<?php echo $row_rs_region['name_cnty']?>"<?php if (!(strcmp($row_rs_region['name_cnty'], $_SESSION['kt_county_usr']))) {echo "selected=\"selected\"";} ?>><?php echo $row_rs_region['name_cnty']?></option>
} while ($row_rs_region = mysql_fetch_assoc($rs_region));
$rows = mysql_num_rows($rs_region);
if($rows > 0) {
mysql_data_seek($rs_region, 0);
</select></td>
</tr>
<tr>
<th><label for="postcode" >Postal Code</label></th>
<td>&nbsp;</td>
<td><input name="postcode" type="text" id="postcode" value="<?php echo $_SESSION['kt_postcode_usr']; ?>" size="12" /></td>
</tr>
</table>
</div>
</div>
</div>
<table class="eC_ButtonWrapper" border="0" cellpadding="0" cellspacing="0">
<tr>
<td>
<input type="submit" name="Checkout" id="Checkout" value="Continue" class="eC_FormButton" />
</td>
</tr>
</table>
</form>
</div>
</div>
</div>
</div>
</body>
</html>
mysql_free_result($rs_region);
Jimmy Wu
It looks like you've applied server validations to the page. The server validations should be applied to the page that the action is pointing to. I'm not sure why the checkout page is redirecting to the index page in your case though:
If you apply client side validations then you apply them to the page that the form is on.
Simply because the whole site runs from a single index.php
with included files based on whichever section is defined in the url (id_sec)
includes are in a folder, in another folder
inc/php/myincludefilewithvalidation.php
section 55 is the shop > shipping details section
the code below is the include
can't see where else validation would be applied
this is where I would normally put it
can you tell me why it isnt working pls
Jimmy Wu
Just to confirm, you've applied server validation, is that correct?
If you have, the form posts to the page that the action specifies, which is the index.php page. When it posts there, if there is no server validation code on that page, it will not validate your form.
If you want to apply client validation, you would apply it to your myincludefilewithvalidation.php page.
