UE 4 Image Upload Problem
Thread begun 4/02/2010 12:30 pm by dlovas275157 | Last modified 4/16/2010 2:03 pm by Jimmy Wu | 2906 views | 9 replies |
dlovas275157
I have upgraded to UE 4 and I am using it for file uploads instead of Digital File Pro.
I have added a file upload server behavior to a file field, but it will not upload the file to my server or record it's filename to my database column.
Not sure what I am doing wrong. I have not had issues in the past.
Attached is my page code. File permissions are set correctly, so I know that is not it.
Thanks for any help
D.
Jimmy Wu
So the image isn't uploaded to the imagesDB directory which is two directories above the one that the ws_inventory_insert.php page is at? Try outputting the debug info to see if there are any errors when you are uploading.
The inserting into your database isn't done automatically, it is accomplished by getting the values returned by the upload server behavior and inserting using DataAssist.
dlovas275157
Jimmy,
Yes. That is correct. The directory is two folders back from the page and permissions have been set to allow upload, and my server has never given my permissions issues so I do not think it is that.
I have used the debug feature, and the insert page (with the file upload sb) outputs the following onload.
img01 debug info
Status object: WA_UploadResult1
statusCode : -1
errorMessage :
clientFileName :
fileExtension :
serverFileName :
serverSimpleFileName :
serverDirectory :
contentType :
fileWasOverwritten :
fileWasSkipped :
fileWasRenamed :
fileSize : -1
isImage :
imageWidth : -1
imageHeight : -1
WA_UploadResult1_1:
clientFileName :
fileExtension :
serverFileName :
serverDirectory :
contentType :
fileSize : -1
imageWidth : -1
imageHeight : -1
Does this mean certain values aren't getting to the upload server behavior?
Steps I took to get where I am now:
1. Generated Insert.php form with DataAssist Wizard.
2. Ran form through CSS Form Builder.
3. Re-binded Insert Record SB to new form elements created by CSSFB
4. Deleted textfield and added file field in its placed (named/id'd the same).
5. Added File Manipulation > Upload SB (see two screenshots attached).
6. rebinded insert sb to Upload FIles img01 > Server FIle Name
These steps worked for me using DIgital File Pro. What am I missing?.
Thanks for your help Jimmy.
Jimmy Wu
Those steps look fine from what you've attached.
The debug information you posted looks like the debug information before the upload is performed. Try putting the debug information on the page that the form posts to and try an upload.
dlovas275157
Jimmy,
My insert.php form posts to my results.phgp page. As you stated, I have copy/pasted the error code and required includes to my results.php page (as they are not available in the server behaviors panel on my results page.
Once I copy/paste them into the results.php page, this is the output:
statusCode : -1
errorMessage :
clientFileName :
fileExtension :
serverFileName :
serverDirectory :
contentType :
fileWasSkipped :
fileWasRenamed :
fileSize : -1
isImage :
imageWidth : -1
imageHeight : -1
WA_UploadResult1_1:
clientFileName :
fileExtension :
serverFileName :
serverDirectory :
contentType :
fileSize : -1
imageWidth : -1
imageHeight : -1
I never had these issues with DFP (previous version). Is this a bug on UE4? What should I do next to resolve?
Thnx again for your assistance. D.
Mac OS X
DW 3
UE 4
dlovas275157
Jimmy,
Have you had any time to look closer at my code? Is it possible to open a ticket as my deadline is approaching?
Is this a bug with the UE4?
Thanks.
dlovas275157
I added "enctype="multipart/form-data" to my opening form tag as another thread mentioned, but still no luck.
Jimmy Wu
I've taken a look at the file, but I haven't been able to determine why your page isn't uploading files. I apply the upload without any issues on my end. I will open up a backend ticket so I can request some additional information to help debug the issue.
Jared
Has The UE4 Upload Image Been Solved
I am having the exact same problem. Has this issue been resolved?
Jimmy Wu
I just checked the ticket and the user created the form and insert behavior again and was able to get the upload working. They said they included the primary key in the second insert behavior, but had left it out in the first one.
